HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Thanks muchly Christian, Greg, John, Carl and David :) .
Jeer Tyes
The jeer tyes support the lower yards. These would have been a fair bit easier to fit before raising the Topmasts  :huh:  .
Two 20" single blocks, one each side, are double stropped with very long strops :
A cleat each side of the mast supports the strops. TFFM suggested the following method of making the cleats to allow the lashings for the strops to be fitted more easily, but after I'd done them this way I think it would have been easier to make them in one piece. The small "feet" at the top were a real pain to fit afterward, and a needle treader can be used to pass the line through one-piece cleats with a minimum of fuss :
The lashings take a little while to fit, as there are six turns around the mast for each (there are supposed to be seven, but I made the lashing line a bit too short  :(  ).
The strops should be long enough for the blocks to sit beneath the tops by about half their length. The yard will sit at the level of the futtock shrouds when they are rigged :
:cheers:  Danny
Cheers, Danny
Super work Danny,
one can think its the actual ship, beautiful rigging
Nils
Current builds
-Lightship Elbe 1
Completed
Absolutely beautiful work Danny! Looking pretty busy up under those mast tops now. Truly a lesson in precision.
GEORGE
Nice clean work Danny.  One of the advantages to come out of my  recent 'error' of incorrect scaling and having to replace my top masts and rigging was the realisation that it was easier to fit the jeer/tye blocks early as you have pointed out.  Still would have preferred not having to remake the masts though :)
cheers
Pat
Thank you too Nils, Frank, George and Pat.
Topsail Sheet Blocks
These are a Shoulder Block. The Lift blocks are seized to them as well. Here are a few pics of a carved sheet block :
My method of seizing the two blocks together. Note the gap in the strops to allow the lashing to pass through :
:cheers:  Danny
Cheers, Danny
Bravo!......skill at both craftsmanship as well as the images provided.......please don't stop!
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Blocks fitted to the Lower Yards
An overview of most of the main yard. There are 23 blocks in total. The Fore yard is virtually identical except for it's length and diameter :
The central portion showing the Jeer Block (top), the Quarter Blocks (lower inner) and the Clueline blocks (lower outer) :
One of the four Stirrups (not yet adjusted and stiffened). Note the three turns around the yard :
The Leechline block (inner) and one of the four small Tricing Line blocks. The Yard Cleats have also been fitted :
The Topsail Sheet/Lift blocks fitted :
And the Yard Tackle block (inner violin block) and the Brace block :
Here is a list of all the blocks for the main yard (the fore yard is the same) :
Jeer Blocks - 1 x 20" single plus 2 x 20" single Jeer Tye Blocks fitted to the mast. These blocks are double stropped.
Quarter Blocks - 2 x 14" single
Topsail Sheet Blocks - 2 x 12" Shoulder
Yard Tackle Blocks - 2 x 15" Violin
Clueline Blocks - 2 x 9" single
Lift Blocks - 2 x 9" single
Buntline Blocks - 4 x 8" single
Brace Blocks - 2 x 8" single
Leechline Blocks - 2 x 7" single
Tricing Line Blocks - 4 x 6" single
:cheers:  Danny
Cheers, Danny
Dan.... Having spent the last two hours on this amazing log, I am completely blown away. This should be a virtual Modelers Handbook in advanced building technique. Can't remember learning so much in only a couple of hours....and that is only your first ten pages! This is not a build to be rushed through. I cannot thank you enough for sharing your work.
Dave
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
After going back into your log Danny, P.100 +, I was admiring your shrouds and I have to ask if you wormed the lines before serving, to smooth out the wavy look of rope when served, or does the difference lie between using 3 or 4 strands around a core when making the shroud? I'm planning on learning how eventually myself, and it seems like a necessary skill.
GEORGE
:cheers:  Danny
Danny,
your arrangement shoulderblock / liftblock looks great.
Just a question : are you securing the block stropping (with glue or so) into the block`s groove, so it wo`nt snap out at the point later on where you do`nt have much access to tackle it once more ?
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Danny
OUTSTANDING! What more can I say. Your step by step instructions will help me a lot when I'm doing my rigging. ..
Bravo for being an EXCELLENT TEACHER or your craft.
Thanks a million million.
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Thank you for the comments John, Dave, John, Kees and Greg. Much appreciated :) .
I sure did Nils. I use a LOT of diluted PVA when I'm doing strops and siezings. It's very easy to clean up while still wet with a Q-tip. The PVA helps to keep the line in shape while I'm tying it.
No I didn't George. At this scale, and with Chuck's rigging line, it wasn't necessary. The Quilting Cotton I used for the serving was sufficiently stiff to "smooth out the bumps" in the line.
:cheers:  Danny
Cheers, Danny
Stunsail Irons
The stunsail irons support the Stunsail (or Studding Sail) Booms on the yards. The booms can be retracted inboard along the yard when not in use.
The iron work for these turned out to be fairly easy to make. I started by cutting the larger inner rings from some tubing of the correct size (which I had in stock) using the parting tool in my lathe. The outer rings are smaller in diameter and width, and as I didn't have any tubing of that size I turned and bored some round stock to the correct size.
Next I drilled a 0.7mm hole into each ring for the legs.
Not having any 0.6mm square bar for the legs I made my own from 0.7mm wire. I bent one end of the wire so I could control which face I had on top, and then simply hammered the wire flat on all four sides. Again, this is a lot easier than it seems at first :) :
I pushed the end of the squared wire into the rings and silver soldered them together. Note that I left the square stock at full length whilst soldering so that I could control the direction of the squared section. I trimmed these to length after soldering :
I made the straps and reinforcing rings from thin card which I dyed with black wood stain. These are glued on with PVA :
The irons fit to the fore upper section of the yard at a 45 degree angle from the vertical :
:cheers:  Danny
Cheers, Danny
Nice Danny, and thanks.
GEORGE
Thank you Carl, David and George.
Figurehead
My figurehead arrived the other day :) . This was carved by Janos - a brilliant job as usual, and something I don't have much talent at :D .
The only thing I really had to do was fit it - this took the best part of 2 hours, as I had to CAREFULLY cut the slot between it's wings to fit around the stem :
All done :) .
:cheers:  Danny
Cheers, Danny
That's the icing on the cake, and some very nice carving by Janos.
GEORGE
Your build is one of the gold standards and Janos is one of the gold standards for carving. The WOW factor just went to 11.
Great "how to" on the iron work Danny. And I guess a great "how to" on carving figureheads as well - ask Janos to do it! ;):P
Seriously though, the figurehead looks great and is another example of this great community helping each other out. Kudos to Janos.
beautiful work Danny,
Nils
Current builds
-Lightship Elbe 1
Completed
G'day Danny
GREAT job again! Your eye for details is amazing. Your ship is now the best. Having two masters, you and Janos, this vessel is have gone pass the out most planet in our solar system in the level of human's endeavour.
Cheers
Greg
Thanks once again Carl, George, Mark, Grant, Janos, Crackers, Christian, Nils, Greg and Mhegazi and also for all the "likes" :) .
Truss Pendant Tackles
The Truss Pendants prevent the yards from pulling away from the masts in a forward direction. There is one on each side of the mast.
Work begins by stropping a thimble in each one. The line turns around the yard and is seized back to itself :
Then each line is passed around the mast and through the thimble in it's opposite number. I've only temporarily tied the yard through the jeer blocks to prevent it from dropping - I'm awaiting some more suitable size rigging thread from Chuck :
The falls for each tackle have a double block at their ends. The tackle passes through this block and through a single block with a hook stropped to it. The strop is long enough to clear the bitts. This hooks into an eyebolt at the foot of the mast. This is the fore tackle :
And the main tackle :
:cheers:  Danny
Cheers, Danny
