Mobbsie, I think what you said is exactly what I was concerned about, (the rat lines no longer being straight). I think you are correct, if you have even tension on both sides when the lanyards are secured, then IF one used proper tension on the ratlines there shouldn't be any issues. Like I said, it was just a thought that flew through my head, and I needed another brain or two to talk it through for me. Thanks to both for your replies.
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Hi Guys,
Thanks everybody for the nice comments and remarks, and also the guys who pressed the "like" button.
I am going to try for an update using IE10, hopefully I've not been scuppered again.
The Lower Main Mast is now done as far as the shrouds and ratlines are concerned and the next step is the Lower Foremast, I have just put the ropes into the black dye in readiness for that, so as far as the pictures go it's mainly the Main Mast.
I have soaked the Burton Pendants with diluted white glue and they are weighted down so that they hang right.
Next up is the completed Starboard side ratlines
Now for the Port side, all the deadeyes had to be retied due to the mast leaning to Starboard, the shrouds on retying could almost play a tune they are so tight, but the mast is now straight and all is well.
This is my method of holding the deadeye and rope so that I can seize the shroud.
You can see by the tails just how much I have had to adjust the shrouds
All the shrouds have been adjusted and the ropes have been tied off and trimmed.
This is my method when tying ratlines, the shrouds are clamped together with two boards , the boards are the correct size for the ratlines and keep them straight, they also help to keep the shrouds from moving out of alignment but care still needs to be taken
Portside shrouds completed prior to trimming up
All trimmed and finished
So there we are, right up to date, a bit long winded I know but it's been a while and I wanted to give IE10 a good workout.
Be Good
mobbsie
Edited by mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
lovely work, roll on me getting back into the Victory build
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
she looks great Mobbsie........the ratlines really look superb!   ....an update of epic proportions!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Interesting idea using that board to both hold the shrouds in place and keep the distance between the ratlines even, i like that better than the cardboard pattern stuck behind the shrouds
Robbyn
Current builds
AL San Francisco II
Completed Builds
In the closet
Battle Station
A workout indeed...for both IE 10 and yourself.
Good work on the re-tensioning of the shrouds and your method for ratlines will be worth a try down the road.  You have just the right amount of tension in those.  Do you glue all the knots or just the ones on the outermost shrouds?  Or perhaps none of them??
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Very impressive Mobbsie, particularly love the Tweezers in the channels photo, really shows just how robust this build actually is, they aren't as delicate as they look :)
Nice work on the ratlines, I imagine a few medicinal pints were ordered after that lot ;)  just to steady the nerves of course!
Take Care Mate
Eamonn
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Great work Mobbsie! :dancetl6:
The rats will be proud!
Cheers,
Jim
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
Thanks guys for the good comments, their very much appreciated.
Augie,  I glue every knot, Sjors very kindly got me some Pattex Special, It's very good and when dry doesn't show up unlike CA which does. It takes about 5 minutes to set so there is time to make adjustments if needed.
Be Good
mobbsie
mobbsie
Next Build :-
Hi great work on the ratlines they look very nicely tensioned and even .
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Nice job on the ratlines Mobbsie.
Lessons well learned !!!!!  :P  :P
And the combination of black shrouds and white ratlines are great !
Great looking ratlines and great idea for jig to keep the shrouds spaced properly.
Lovely ratlines.  A big job done really nicely.
Colin
Current Builds: HMS Pandora 1/64 Scratch
                         Jeannie Johnston;
                         18thC Longboat with my son
Previous Builds: HMB Bounty - Caldercraft
Running Round my head: HMS Speedy (1782) - vaguely thinking POF
"If at first you don't succeed, try it your wifes' way"
CONGRATULATIONS on a great log of a superb build.   Im just about to start rigging my Cruiser and have been doing some research through the forem and books and so far your log has been very helpful especially as a lot of the terminology is new to me . Your pictures explain so much.   I think i have all blocks and eyes on the masts and believe my next move is to clue masts to hull followed by fitting shrouds and ratlines    My question to all you more experienced riggers is if i fit the lower shrouds now will they not be in the way when i get to fit the running rigging . I APOLAGISE  for asking questions on your log but you seem to have a lot of expert followers .Once again FANTASTIC build and keep the good work and pictures coming
Wow, thank you all so very much for your very kind comments and remarks and the like button, I didn't think for one moment I would get a response like that. :)  :) :)  :)
Lawrence, I use 2 made up lengths of timber made up to the size of the spacing, they go either side of the ratlines and are clamped into position using small bulldog clips, there is a picture of them fitted to the shrouds in my last post, hope that answers your question mate. :P  :P
Shihawk, Thanks for looking in and I'll try to answer your question. To make it short the answer is YES, but whatever lines you do first they all get in the way of each other, there is an order that must be followed which will save a lot of aggro later. It is thought to be better to work from stern to bow, but this is a matter of preference. ;)
I have found out by reading other logs from builders who are a lot better and experienced than me that it is better to start on the Mizzen then Main followed by the Fore mast and then the Bowsprit. After the Masts have been stepped ( do not glue ) it is best to complete the lower shrouds and ratlines. When you have completed them move back aft and start on the Topmasts and then the Topgallants, it is recommended that the Standing rigging be completed before you start on the Running rigging. :)  :)
Unfortunately it's in this type of vessels nature to make life a bit difficult and so you generally find that most of the ropes and lines will get in each others way, this will test your patience to the limit but life can be made a little easier by getting rigging tools. All I can suggest to you is that you study the rigging plan and follow that as best you can, if you have Caldercrafts Cruiser then the rigging plan will most likely have the best method of rigging.  :mellow:  :mellow:
Good luck with whatever you decide to do. :)
Be Good
mobbsie
mobbsie
Next Build :-
Mobbsie, I'm just catching back up on your build, your ratlines are superb.  Love your method with the alignment sticks!  That's one beautiful build you've got going there. keep it up!
Wes Cook
Current Build: USF Constitution (Model Shipways)
USF Essex (Scratch build)
MS Syren (build log lost, need to rebuild)
Future Builds: MS Confederacy
I'll take that as real compliment coming from you Wes, compared to you I am a mere Loblolly Boy.
Be Good
mobbsie
mobbsie
Next Build :-
Now Mobbsie, I haven't tied the first knot....  Don't know a clove hitch from a what-knot.  (well I do now....)  Gluing pieces of wood together is one thing, but rigging?  When I get to rigging you folks are gonna watch me shed some tears for sure....  And use sailor's language.  I just hope I can come close to the many ship builders here, you included!
Edited by cookster
Wes Cook
Surely you don't mean to imply that Mobbsie would use such language as to peel paint from a barnacle????
:D :D :D :D
Looks good there, Mobbsie.  Very impressive!
:ph34r::piratetongueor4:
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
I have to admit gents that I have made milk curdle quite often so we have no shortage of yogurt at home, with a little practice I reckon I could strip paint which would be most beneficial right now. :D  :D
Just as a quick verbal update I am currently putting the shroud cleats on the Mizzen and Main masts, no information in either the manual or sheet plans so that called for a quick email to Jotika, the answer came the same day and was really comprehensive. :)  :)
For anybody waiting for Caldercrafts HMS Surprise to come out, it should be out later this year, Jotika have stepped up their production with new machinery and workshops, I know we've heard it all before but this time I think I believe them. ;)  ;)
Be Good
mobbsie
mobbsie
Next Build :-
Be Good
mobbsie
Hi Mobbsie - that is very interesting news...I'm now in a bit of a bind because that might coincide well with when I'm likely to get my Snake finished.  I had my heart set on the Aggie but the Surprise could be the new front runner!
Cheers,
Jason
In the shipyard:
Great news. Have you heard anything about their 74?
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
