Michael - the computer keyboard reminds me how big your model is. I do like the opportunity for detail that it presents. I must consider building smaller ships at larger scale in future.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks very much Michael, stow that away as well.
I had to look twice at the cabin paneling with the cushions in place; I thought it was the real 'McCoy' you were using as a reference, not your scale version.  That is impressive!
cheers
Pat
Michael...just wonderful paneling work and the machining....oh...so nice.
Rob
Current build:
Finished build:
Current build(On hold):
Thank you everyone for your kind comments they are appreciated.
While working on the paneling I discovered that I had in my quest to have the floor and the end wall fit through the opening in the deck I had overlooked the issues of the door opening and not fouling the area below the seat cushions, I had been so concerned with the integrity of the floor component and that it be easily removable that the stile next to the door with the hinges was wrong I had made it too short because I had a bit of tunnel vision thinking about the strength of the floor box. this picture shows the problem
My thinking was focused on the side panels and how they would slip in and lock into place. so when I placed the panel into the boat it looked like this.
You can see the problem. So I decided to take off the solid end wall behind the paneling and removed the short side walls that gave the inset some integrity and had a rethink. By removing the solid panel it opens up a whole new vista which is better, My it would have been better to have thought about doing the interior before getting to this stage. so now I find myself working in some tight spaces, I need one of those magic reducing spells to miniaturize myself. Oh well! so now without the side walls and end wall.
In order to give the floor a better integrity I cut some new maple floorboards that run the full length of the kitchen dining area these are just laid on top of the old fir floor loose at the moment. Now with the port side panel included after adding an extension to the stiles on both sides it looks more like the one inside Integrity which I am using as a general guide.
And this then makes having the door opening make more sense, because I can see through into the forward area around the mast.
All I need to do now is figure out how to make all this work. I am having a lot of fun even if I take two steps forwards and one  step back half the time.
Michael
Edited by michael mott
spelling
1 hour ago, michael mott said:
Michael, you'd have no trouble convincing me that this pic was taken in the full size boat!
Spectacular work from the keel up, inside and out.
I quite agree with Bedford.
Just beautiful. I can’t quite tell if u carried the same board down on each door...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
To mirror everyone else who has commented - stunning work. Well done Michael. The most fun part is solving problems.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks all
Before finishing the forward bulkhead location and fitting in place I needed to add the hinges to the door, this requires more substantial hinges than for the cupboards so I followed a slightly different approach without annealing I folded some .016" brass in the same manner as before but I cut off one side of the fold with my old No 45 Eclipse razor saw I only cut 90% of the way through then bent it away and down a couple of times to released it through work hardening it.
Then instead of using a wood support I used some 1/8th brass.
The three hinges are now roughed out time for some lunch.
Michael
I'm not sure where you are going with this, Michael, whether you have construction plans for a specific vessel or you are presently building conjecturally, designing as you go along. I've had a fair amount of hands-on experience with this type of layout, owing a small British cutter for many years and having sailed on several larger British pilot cutter types, including one very similar to what you are building.  While I have no idea of your present intentions, I'll pass along the observation that the type of saloon door you are building here, in my experience, invariably is hung to swing forward, rather than aft into the saloon. This maximizes the sole space in the saloon, particularly if a table is set on the centerline. Frequently, there will be a second bulkhead with identical doors forward of the saloon bulkhead. The distance between the two bulkheads is the distance of width of the forward and aft bulkhead doors. The doors in the forward bulkhead swing aft, such that the edges of the forward and aft bulkhead doors meet when when opened all the way to right angles with the bulkheads, edge to edge, and form a short paneled companionway between the saloon and the forepeak.  (There are hooks or barrel bolts that hold them open in this position.) With the doors of both bulkheads closed, the space between the bulkheads will become the head compartment, with the commode to one side and a hanging locker or even a shower on the other, each being concealed when the doors are fastened in their open positions.
I don't know if this comment is helpful or not. It's not intended as a criticism, to be sure. The work you're doing is really beautiful and inspiring! Thanks for sharing it with us. I realize the time commitment involved in providing a build log of this magnitude and it's most appreciated.
Hi Bob thanks for your comments, they are interesting. For the purpose of this conversation regarding design I will add four pictures of the interior  of Integrity  built recently by Stirling and Son These pictures are from web over the last few years some of these pictures were originally on Stirling and Sons site and a yacht brokers site and do not appear to be there any more. so they have the copyright.  and I credit them for that. If this contravenes the law then I will remove them, my only intent is for clarification of this conversation.
This is a plan of the yacht Integrity
I have been using these images as my guide for the interior of my Model cutter which is a rough example of the cutters of the late 1800's early 1900's it is not a model of any particular boat but draw upon things that I like that are on various cutters. When I began this model back in 2012 I had no idea about plank on frame model boat-building although had many years of commercial model-building going all the way back to 1966 when I built the mechanical arms for the Movie 2001 while working for a small model-building company in Acton called All models Engineering so I figured what could be so difficult about building a model of a sailboat.........Yeah right! did I have a lot to learn, and it is a continuum that is still unfolding everything that I have learned about model boatbuilding I have really learned in these last 8 years. I spent so many years build very accurate models for other people following their plans that were challenging but not in a way that was totally satisfying and during those years I did not do much in the way of model-building as a hobby that was the last thing I wanted to do.  My goal is to learn and to stretch my skill level by taking on challenges that I have not done before (probably a character flaw that was programmed at birth) but I have fun following these rabbit holes.
Back to this model if you go back over the build log you can easily see that I have redone many things and had to re-thing all sorts of areas this is a result of not having a working background on this particular type of boat. I have designed and built a yawl which I sailed successfully for a few years using an old fiberglass hull as a starting point. This has given me a better understanding of the physics of sailing. Because i lived at the lake when I started building this model.
Tthe hull is based on the Model Maker Plans for a fishing smack called Kingfisher which I purchased in 1972 the plans called for the model to be about 18 inches long. Well as soon as an 18 inch model gets 10 feet off shore it looks like a toy I wanted a model sailboat that had some scale to it (I also had lots of room and a 12 foot ceiling) So I chose a scale that would bring those plans up to about 5 feet the hull from stem to stern is 63 inches the bowsprit is an additional 21 inches I chose a scale of 1 1/2 inches to the foot because I knew it would give me the opportunity to make working details and use real nuts and bolts (at least the big ones) 1/32" = 1/4 inch so the ratio 1:8 it is also much easier on my aging eyes.
In the beginning I also was going to radio control this model, so the interior didn't matter this was a model of the outside of this boat. As I continued this journey my ideas changed (the beauty of not being restricted to a model of a particular prototype) and so the elements on the model had to change, none of this model is precious its all just stuff that is the foundation for learning what looks good to my eye (sort of like an abstract painting) If I need to change something it get changed I don't have any qualms about that at all. That stuff goes into the used materials boxes whether it be metal, wood, cloth, to be recycled into something else down the road.
So I moved away from the lake and back to the city, and the model was put aside for a while while other challenges tickled my mind (now the loco is aside, but it is of a particular prototype even so one has to make compromises because you cannot sale molecules) now that I am back to sorting out this cutter I realized that it will spend far more time on display than in the water why don't I put some interior into it, but it has to be removable in order to put the lead ballast into it when I do get to sail it. As long as it can sail and I sail it at least once or twice That will be good.
I looked at many pictures of cutters and smacks and the Gentleman's Cutter by Stirling and Son which is a modern cutter drawing upon tradition values of design and integrity just hit a chord for me in many areas. So I am using its aesthetic as a guide for my own ideas and the limits of what I have to work with.  I hope this answers your question Bob about where I am going with this..... its a moving target to coin a phrase.
Now that that is out of the way
I began fitting the hinges to the forward bulkhead door
They are fitted into some chiselled recesses and taped down ready to drill the holes, then when the hinges are complete I can work on the door lock and handles
Michael
Thanks for your detailed explanation, Michael!
Yes, Stirling and Sons' Integrity is a traditional pilot cutter design in hull and rig and well-respected. She's a beautiful boat. Her interior accommodations are not at all traditional, however. They've built the interior with period cabinetwork, but the layout is thoroughly present-day. This makes her far more marketable today of course. The number of berths is a dead give-away. These may please the owner who expects to be asked over and over again, "How many does she sleep," but the shortage of space for sail stowage, provisions, and other gear handicaps her as a truly practical cruising boat. Ironically, the traditional pilot cutter would have had close to the same number of berths, but these would have been the distinctive "pilot berths" to port and starboard above and behind the setees in the saloon. "De gustibus non disputandum est!"
I see where they've installed one of the somewhat rare and highly desirable bespoke Pascal Atkey and Sons (Cowes) "Pansy" charcoal cabin heaters, theirs being the copper version. (to the left in the photo below) That's a nice traditional touch, to be sure. (I've got a stainless steel one with all fittings, in excellent condition, sitting on a shelf in my workshop and for which I have no present use. If anybody's interested... :D )
A small update
I began sorting out the door lock this sketch gives a general overview of the design
First some 1/2 inch diameter hard brass was prepped on the mill by cutting a slot across the hole which is .106" in diameter the slot width is .193"
The pawl or central spindle was checked for clearance the square 1/16th tube was soldered into a disc of 3/16 brass that had been turned down to create a 1/32 inch flange that was shaped to create the teeth.
The slider that will become the latch part was prepped again on the mill  creating the tabs to engage with the pawl.
The slider was fretted out with the jewelers saw.
after some filing the slider was test fitted into the base plate of the lock, I have a watch holder for Bulova watches that I acquired with a bunch of watch making stuff about 10 years ago
The pawl was rotated with a watch winding key to check to motion of the slider which has to move .062" back and forth.
IMG_8979x1024.jpg.15de54663d10ddaee11939820be9eaec.jpgIMG_8978x1024.jpg.9f9abf2f95d4451182811f4b3346ee55.jpg
Then the top plate was fitted to further check that the slider will not jam here the slider is out or in the lock position, the latch will be soldered between the forks
And in the open position
Still a ways to go but I am confident that it will work.
Michael
Michael,  my mind is truly blown at this point.  Working door latch at scale.  I'm in total awe.
3 hours ago, wefalck said:
I like these modifications to the movement holder, particularly the downhold fingers.
Eberhard the holder is as it came in the small case I have not changed or added anything, and it also came with a separate set of nylon posts for holding watches in their case the posts I am using are for movements that are not in their case
Mark thanks but this work is crude compared to a watch mechanism, think of a ladies 21 jewel Swiss watch.
5 hours ago, G.L. said:
you are really going far into detail.
Geert this is absolutely why I enjoy this scale so much, it does allow me the flexibility to try to make parts that otherwise would be too small.
5 hours ago, Bob Cleek said:
That door latch is a great example of the joys of working at larger scales!
Yes Bob and really for me the work is the joy whether it is a hinge or a set of shackles or the rigging for the topmast this scale allows me to try things that would be extremely difficult at smaller scales.
I also enjoy the process of documenting the work and being able to share the ways I work, it seems only fair to me because of the immense amount I have learned from following many build logs and other areas on this amazing forum.
Michael
Splendid woodwork and machine work Michael - everything looks so very nice!
Not a character flaw - a special personal attribute.
And I thank you for doing so.
Looking forward to what’s next.
Gary
Completed Scratch Builds
22 hours ago, Bedford said:
And here's me bailing on the idea of creating 1:8 scale shackles!
Mind you the full size ones only have a 6mm pin
Steve sorry I missed replying to your comment, I actually did a lot of work on different ways of making shackles earlier on the build I cannot remember where in the sequence 6mm is basically a 1/4 inch no problem that's only 1/32"
14 hours ago, Kurt Johnson said:
 A book wouldn’t be bad idea either.
Kurt I have thought about a book, it would need a fair bit of work though because of all the two steps forward and one back that seems to be my way forward. LOL
Thank you Druxey and Gary for your kind words.
A bit more progress on the lock, first I turned a bit of hard brass to the width of the slot in the slider part then  sliced a bit off on the mill then used the jewelers saw to cut the small bit to fit between the ends ready to solder in place.
After the slider was filed to shape, it was placed into the body to position them ready to be glued together for drilling and tapping then I used a Walthers 00x90 tap for the screws to clamp the body halves together.
  I cheated and turned the 00x90 hex bolts into some small head flat head screws
Next the lower body plate and the slider were drilled for the spring, I ended up with about half a dozen springs before latching onto the correct design.
With the spring in place (.011) music wire spring I have miles of the stuff in anyone needs any.
the door is mortised and the retaining plate is ready to be slotted and drilled then be soldered to the lower body plate.
And the pencil for scale
Good night Michael
Yeah Michael, 1/32" isn't impossible but with my tooling it's not yet something I want to take on.
I might get to them at some point though, never say never!
Meanwhile I'll just watch your beautiful workmanship
That is just outstanding Michael. Where did you find the giant pencil? 😉🤣
Grant it is part of this set that I made back in 2006 for my son in Victoria. LOL
I actuall only made a couple of giant HB pencils for a display at the Edmonton Science Center that framed a customer comment station, at the end of the display I was able to keep the pencils, my son is an artist so I gave them to him he now has a studio in Whitehorse and has it hanging as a sign.
I like to draw as well here are a couple of my drawings that my son has in Whitehorse. They are imaginary gourd type harps loosely based on the instruments that were catalogued in a book that was of the instruments of the peoples of the Congo area in Africa in the early 20th century
Every once in a while I will sit and draw .
So there really are giant drawing tools out there.
4 hours ago, Gaetan Bordeleau said:
Impressive brass work Michael, Bravo!
Thank you Gaetan, I have drawn inspiration from your own work.
Steve, when you get round to making shackles let me know I have a lot of pictures of the process.
4 hours ago, SpyGlass said:
sneaky introduction on new crew mwmbers was to let the anchor chain run out while the new hand was seated!
Ah but then I would need to install a sound system and electronics is one of those mystery subjects all I know is there is a + and a -
And thanks to all who have added likes and a are following along.
Michael
