Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Thanks Mark, and to every one else.
I'll be starting the next 2 boats in the morning.  I'm going to work them at the same time as it'll save me some repetition time like having to reset the laser for each thickness of wood since I can cut two with one setting.  I'm finishing up tweaking the drawings from what I learned on the first one.  So diving off the deep end again but into familiar waters.
Link to comment
Share on other sites
hey there Mark...........just caught up with your log!   sorry to hear that you were having problems.......haven't visited here as much as I would like to.   I'm hoping to find my way back to the wood side soon ;)    glad to read on that things have gotten better for you,  but I'll keep my fingers crossed that you can get back to a norm that makes you happy.   great job on the ship's boat.......looks like you've rekindled the mojo to continue with this project. :)
truly super job.......keep good thoughts
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks for the likes and comments.   Time for a proof of life update.
Life has gotten quite a bit quieter lately, which is good.  So I focused on these little boats.  The barge (the middle sized one) jig went well and so deciding to be bold and do both at the same time, I started on the cutter jig.  Hmm... not so good.  It's smaller and everything is proportionally more fragile.  So.... spent a lot of time remake parts that I broke in the fitting.  I solved the breakage problem by reducing down the laser marking in thickness and expanding the "bits" that hold the pieces together.  Ended up coating many of them with 2 coats of white glue and water.  Seems to work and tests say I'll be able to snap those naughty bits on the lines without damage.
The jigs are built, the keels installed with few other necessary bits and pieces and I'm ready to start actually building the boats.  So, I'm off to fix the ribs and start planking.  Here's a photo of the jigs and the larger boat (finished).  The Longboat (finished) is 6 inches long (152.4mm), the barge is 5 inches (127mm), and the cutter is 4 inches (101.6mm) long.
Link to comment
Seems you have these boat skeletons all sorted in the death star now Mark?  Looking good!
cheers
Pat
Link to comment
Thanks for the comments and likes.   As brief update, the small one is being started over again as there's some issues (probably I'm the issue) with the thinness of the woods for the jig and smaller curves for the frames.  I'm reworking and rethinking this as I plank the larger one.   And then there's life getting in the way in good way.  Ran into an old friend where I used to work and we're seeing each other.
Link to comment
Finally... an update.
The two remaining small boats are on hold for now.  I needed a change of pace and break from those fiddly things.
I've installed the forecastle and quarterdeck beams.  And also installed the pumps.  Clearances have been checked and re-checked for rigging to come at a much later date.
Next up is planking the decks and associated bulwarks.  I'm starting with forecastle.  Here's photos:
5-20.thumb.JPG.6265fc160024a35bafaa90f2acb90e82.JPG7-1.thumb.JPG.da98addd30cc6cf1627be961c627de89.JPG6-1.thumb.JPG.1ddd672e0b6c2c0aa465aa5c23ac598c.JPG5-21.thumb.JPG.621d1e6390f83071f90e0dc9af51c8a5.JPG
I had to get the camera repaired and it would appear that the repairs were successful.
Till next time.
Link to comment
Nice work, and clear photography :)  Won't be long before you have the upper deck planking on now Mark ;)
cheers
Pat
Link to comment
Fantastic work!
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Link to comment
Lawrence,
If I remember right, it was an X-acto handle with an X-acto saw blade.   These are at the blades: https://www.amazon.com/Xacto-X215-Blades-15-Pkg/dp/B000BREQDO  The Handle is this one:  http://www.xacto.com/products/cutting-solutions/knives/detail/X3261
Link to comment
Really nice work mark  - she is coming along lovely.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
I thank you for the likes comments.  But I do have sad news.  I'm indefinitely pausing this builds.   There's some minor errors but basically, since what has happened in my personal life, I can't stand to look or work on her.   So for now, until I can get through the healing process, she will be, as the British Navy would say: "In Ordinary" pending further decisions.
Link to comment
I'm sorry to read of your situation, Mark. I hope that things will improve for you sooner rather than later. In the meantime, my best wishes to you.
Link to comment
Mark,
I can't express my feeling and concern for you any better than druxy did. My thoughts are with you.
John
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                            Iron Clad Monitor (complete)
                            Sardine Carrier which I will Name Mary Ann (complete)
                            Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
Link to comment
Sorry to read that, Mark, but you know your heart. We'll be here for you when you feel the need👍.
Ken
Started: MS Bounty Longboat,
Link to comment
Mark, I'm sorry to hear this. I do want to thank you for sharing all that you've done thus far, so many of us have learned so much from you. Whatever choice you make down the road, you've helped so many people by sharing this that the project is already a wonderful achievement.
Link to comment
Mark, sorry to hear about your situation. I wish you the best.  Like everyone else has said before, we will be here when you are ready.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Link to comment
Mark, I pray you find something or someone to ease the pain till you heal. You have friends here and each is willing to listen should you need a ear.
Link to comment
Mark,
  I'm sorry to hear this.  I hope things get better for you.
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
Thanks gentlemen.   I have a local support system (my psychologist and my lady friend) and this seems to be the best way.  Things have improved emotionally from what they were a few years ago, and will continue but for now, I have to put her away and clear my brain.  The old saying "time heals all wounds" applies.
Don't expect to see much progress reported on my La Belle-Poule build as I'm reworking the drawings to size and converting many to be cut using the laser.   Once that's done... rock and roll time.
Link to comment
So sorry to hear mark we will stiil be here to support you and follow your build when you are ready to return,
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Stay strong mark, you can do it and licorne will be patiently waiting to come out of ordinary
Best regards
Paul
Edited by paulsutcliffe
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
Mark,
 Your support group will be the beacon of light to get you through the darkest days.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Link to comment
My thoughts are with you Mark.
Cheers,
Jason
In the shipyard:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
