Thanks Sherry....... I'm really enjoying the planking this way, hopefully the rest will be as enjoyable!!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
HI Bindy..... thanks for your input.... yeah, I'm really liking this method of planking now, planking has always been a hang up for me, but trying this way has opened a whole new "planking world"  :D  . There's a little more prep work and time involved but I think it's worth it.
Frank
                         USRC "ALERT"
Hi Sjors.........  I'm still here  ;) ..... I'll have an update soon ( I hope !! )..... I've been really busy trying to finish up planking the hull, I've got one more band to do p&s, then I'll be finished. I have to do this while I'm still in the planking mood or else  I'll never get finished :D . so hang in there,...... in the famous words of our beloved Gen. D. MacArthur... "I shall return".. I don't know when , but I will :P
Frank
                         USRC "ALERT"
Hello Frank,
due to the fact that I ordered her,too, I'm following your build with high intrest.
You plan to build her double layered planked?
Thanks a lot for showing your kit's progress,
Yours
Stan
Edited by Small Stuff
My carpetmonster adapted to laminate flooring!
GK - Modellbau No. 2002 a little boat 680 after E.Paris  - PoF 1/50
AL 18021 Scottish Maid the 1st Aberdeen Clipper 1839 - PoB 1/76 (?)
Dream: a hullmodel of the 66 55/95 tons US-Revenue drop-keel Cutter 1/2"=1ft, plans by H.I.Chapelle
This confuses me as well.  I consider length overall as bowsprit tip to spanker boom end.  But then there's the length on deck and the mysterious length between perpendiculars.  Length at the waterline adds still more to ponder.  Measure up the plans, do the math and figure out what size case you need and where you're going to display her.
Have we 'officially' decided that this is the 1818 US Alert?
Hy Augie, sorry for writing in here but it might be a very old but important question - helpful to a plenty of members confused by diffent length(e?)s used to definite a ships proportions.
These diffrent length(e?)s are not too confusing if you look onto this drawing - source wikipedia:
Hth,
Chris
Like I told Sjors last month ,"I will return", well, I'm returning..... with an update that finishes up the laying of the Alert's hull. Still need to sand it up and doctor it up here and there. It was a lot of fun planking the hull this way( spiling). There's some goofs here and there but after all is said and done, I can live with it ... it could have been a lot worse!! :P . The only thing I was a little disappointed with was the basswood. It's not that it's hard to work with,it's ...ah,... just not that good. .... I don't know if there are different grades of Basswood available, but I certainly didn't come across any. Although I shouldn't complain , the price was definitely all right!! Thank God for stains and paints. :D
Well enough complaining :rolleyes: .... following are a few pictures confirming that I really did finish !  All comments  good... bad.... or indecent. are welcome!!
This shows the transfer of the outline of the plank to the basswood . I then used my ships curves to make the final lines.
 this is the last stern strake being set on the s.b. side
final strake being set on p.s.
Following pictures are just different views of the completed hull . Thanks for looking in!!
Frank
Thanks again Russ for all your help!!!!
Frank
                         USRC "ALERT"
Sweet planking, Frank.  The runs of the strakes look great.
Frank,
very nicely done hull, I like the lines
Nils
Current builds
-Lightship Elbe 1
Completed
Great planking Frank. A sweet hull is in your hands.
Cheers
Alistair
Current Build -
I have no idea what your talking about Frank..... the planking looks swell!   with a good sanding,  you should be able to leave it as a single plank  {if the plans call for double}.   well worth the wait......ya did good Frank!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I'm a little late and everything is all ready said......
But ok, for you I will say it also.
Nice job on the planking Frank !!!!!!!!!!
And thanks for the pictures  :D  :D  :D  :D  :D
Sjors
I know everyone is busy with their own projects, so I'd like to thank you... Mark.. B.E... Dirk... Nils... Duff... Ron... Alistair... Popeye...
Grant... Mike... Scoot.... and Sjors... for looking in and supporting mine... Thanks again
Frank
                         USRC "ALERT"
Hi Frank,
I love those lines mate, she will clean up beautifully and you may even get away with a single planking.
All the plaudits are well deserved mate, you've earned them.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
A small update..... My first ( and I hope my last)  Alert repair!!...... I was just starting to set the last 2 strakes
and when I started the star-bord side I ran into a little problem.  while trying to fair the bottom plank I took off to much on the top of the plank, so when trying to fit the one on top of it it just wouldn't sit right, so I decide to yank that plank out and start from scratch, because I know that would have really bugged me, but as  things go, while removing that one I screwed up the one beneath it ( and I thought I was so careful) :o well what
was supposed to be a band aid treatment became  minor surgery. For fear of screwing up any more planks I soaked that one real good with alcohol . As you can see in the last picture the procedure was  a success !!
 Now all I have to do is get it back together again. I'm so glad this is scale planking!! :P :P
Frank
This is the first plank removed, as you can see the next plank had a piece chipped right near the stem, Thats what prompted me to remove that one also
This is where I carefully soaked and started to remove the second plank
Operation finished!!! Like I said before , I'm glad these are scale planks!!!
Frank
                         USRC "ALERT"
Frank,
Let's be glad these are scale planks and that a bit of alcohol (on the planks and sometimes in the builder) help immensely.  Nicely done on removing the offending planks.  ;)
As for the "last repair"... hmmm... I always thought that's we did.. non-stop repair?  :o
Thanks Mark........ Just finished cutting one of the new planks, I'm taking a breather to-nite so tomorrow I'll fit it in . i guess you're right, we're always repairing when we build :P
Hi Mike....... it's always frustrating when something goes wrong, but it's better to fix it now and be satisfied, that would have been a real obvious goof!!
Frank
                         USRC "ALERT"
