As my first plastic ship model, I decided to start small and go with the Pit Road IJN destroyer Hatsuzakura ("year's first cherry blossom") with FiveStar PE upgrade set.
For a little about the Hatsuzakura, it was a Tachibana class destroyer that was completed in May 1945 and served for the remainder of WWII.  This ship is pretty famous for being the ship that met the American destroyer in Tokyo Bay to discuss the entry of the Third Fleet for the surrender ceremony.  After the war, she repatriated overseas Japanese citizens back to Japan.  Later, in 1947, she was given to the Soviet Union who used her as a target ship and she was scrapped in 1958.
324591271_Tachibanaclassdestroyer.gif.a7c5fa05bd5d2b0c331277a4b1858c3a.gif1828144849_Hatsuzukurapostwar.jpg.03c78d3d33105db2e0587739090e7ddf.jpg
I had bought a couple of nice 1/350 kits, but decided to start with a relatively inexpensive 1/700 kit to gain some experience (as I hadn't built any plastic kits since I was a kid).  I ended up picking up the Hatsuzakura given that destroyers are a bit simpler, and this particular kit had a fairly extensive upgrade kit from FiveStar.  I probably would have been better off with a 1/350 kit since the PE on this is microscopic - literally hair thin in many parts.  I'm hoping that all the time I have been spending with the 1/700 PE will make the 1/350 stuff a breeze.  I have a few other 1/700 kits in the stash though - mostly auxiliary ships like seaplane tenders and repair ships - as I tend to like less common things, and 1/700 is generally the only scale you can find these kinds of ships.
I've been working on this off and on for a few months now.  Here are some build pictures:
Bridge
IMG_8534.JPG.9f9794f62cb08e9dd1c10d5af67ddf18.JPGIMG_8535.JPG.453f681685e1791d01162e35b56823d2.JPGIMG_8576.JPG.e3bafee68232916304428f96d35ea3fb.JPGIMG_8578.JPG.00d7b22074adf1c3c26ac2dd61228a4d.JPG
Funnel - in second picture, can see how much improved parts look with PE given that the plastic tends to be way over scale (especially at 1/700)
IMG_8685.JPG.3fdf77ee082afd546455aa0af8227f1e.JPGIMG_8688.JPG.1afb9d9cb7873810f54dde199aa419fd.JPG
Rear gun platform - those little triangles were added underneath as supports!
IMG_8690.JPG.ac947bf0f1db0c72916d2a2c47e0cb48.JPGIMG_8691.JPG.d89766edc606b5657cbe79836bf4eb97.JPG
Here's where I am today.  I've been trying to figure out the best order to build and paint these.  This particular destroyer has parts of its deck in linoleum, which makes painting a lot trickier.  I've painted the linoleum sections, and then spent a few hours cutting up Tamiya paint mask tape into tiny pieces on the order of a couple of millimeters to mask it for when I paint the steel sections.  Probably a good two hours of work to mask about two square inches of deck 😳
The trickiest thing at this scale is the PE - this stuff is so thin in sections I swear you can breathe on it and it will bend.  I need to straighten out the main tower, but after bumping it accidentally a few times, I don't want to keep fixing it because over time the pieces will just snap.  So, it's a little bent at the moment.
All in all though it's been fun and I've gotten a lot of experience with working with PE, gluing it, using my airbrush, etc. that when I go to 1/350, I should be in good shape.
My hat is off to you  Mike. You are a far better man than I. I have no interest in torturing myself at that scale!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
I agree with Lou,   I tried building a Destroyer  in 1/700  scale  but lacked high mag  viewing  and good light  - so I really struggled  also used hand painting in too think layers  -  you are doing a Fab job.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Wow... first plastic and PE and so darn tiny.  Just Wow....  looking like you've doing this for years.
Wow Mike! My hat is taken off and doffed.
You weren't joking about the pe parts being small.
Excellent work!!
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
  • 7 months later...
The diorama builds from @CDW and @Egilman inspired me to dust this one off and get back to it.  I was a bit burned out cutting 1-2mm squares of tape to mask the linoleum deck, and got a little stuck in figuring out the build sequence given that a number of deck items to be painted gray would sit on top of the linoleum parts.  I think what I'm going to do is get as much done on the ship as possible that isn't on the linoleum, paint it, then after removing the tape, separately paint the remaining items and add them to the model.  It's going to be tricky as the PE is so small.  I might just prime and paint the frets, then assemble the pieces, rather than assemble and then paint as I've been doing here.  That's the only way I think I can get it to work.
In any event, I finished building the bridge and bridge tower, and added the rear tower (not sure if it was for radar, radio, etc.?)  which was a very intricate and tiny piece with at least five bends and probably a couple of more:
I've gotten a lot better at working with PE this small, but it's still a challenge.  Some of the pieces are like thick hair in diameter.  So, you have to be very careful not only extracting it from the fret, but also in building it up.  This Five Star set doesn't have any detailed instructions for the most part, so you are forced to study the pictures and diagrams and figure out how to bend the part to completion - some of these are like origami with a number of bends and folds, and the pieces are so small that even my smallest Swiss tweezers seem too big at times.  Optivisor is an absolute must!
Thanks for looking in!
Edited by Landlubber Mike
I missed this one? glory beeee....
Brother you pull this one off there is nothing you cannot build.....
My eyes are just too done for that scale... I've done quite a few 1/700 before and actually had a 1-700 Kido Butai display, (was only missing the tankers) but I sold it cause it was just too large for my space.... (6 aircraft carriers & two battleships in dual column formation will do that to a display)
My hat's off to those who can do PE in this scale and make it look good....
I respectfully doff my hat to you sir.... You are braver than I...
Quote:
Thanks guys, we will see how it goes.  I've always had very good finger dexterity, but the eyes are another thing.  For most of my life I had great near vision, but now in my mid-40s, that's kinda going south.  So far I'm fine with the Optivisor but my guess is that the sands are running out of the hourglass on these kinds of models.  Too bad as I love this scale for just the sheer number of different type of vessels, especially on the auxiliary side.  I've picked up a number of kits from oilers to repair ships to submarine and seaplane tenders, etc. as well as the more standard fare like cruisers and battleships and aircraft carriers.  I'm also hoping to display them as waterline dioramas, which is a little easier at this scale (or at least they will take up less space) - big reason why I'm taking a big interest in your waterline techniques!
I originally picked this Hatsuzakura as a fairly inexpensive way to learn how to do PE before tackling my 1/350 ships.  Little did I know how tricky PE is at this scale!  When i get back to my 1/350 Shimakaze, I'm sure the PE will look huge.  I'm chomping at the bit to get to some of the other 1/700 kits in my stash though.
Ultimately, this is what I'm working up to.  Only 15 sheets of PE 😳  There's a lot to do with the pagoda tower, lattice work, etc.  I figure this has to be one of the ultimate PE subjects if you are a masochist.
5 minutes ago, yvesvidal said:
Mike,
At the scale of 1/700th, this is self inflicted torture. How much are you going to spend in chiropractor and therapy after this PE set?
Yves
Good question Yves.  So far I'm self-medicating with tequila and bourbon which seems to be going ok.  The interesting thing is that despite the complexities of working on this one, I've been fairly even tempered and not at all frustrated.  Maybe it's from having super low expectations.  My 1/72 and 1/48 planes on the other hand drive me nuts as I seem to break things off almost as soon as I can put them on.  Probably the worst for me was working on my 1/64 Badger build - I can't tell you how many times I broke a cannon loose off the deck, or an errant elbow hit the bowsprit or a spar and popped off the rigging.  No amount of tequila or bourbon could settle me down when that happened!
I hear that a lot of #%@$$#^^**#%@$ type language helps....
Quote:
These days when asked about kids I just ask "which generation"?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Mike I have to show you these  as inspiration  to carry on  - some truly amazing work being done at at this scale  -
https://www.britmodeller.com/forums/index.php?/topic/235085055-hms-prince-of-wales-battleship-1700/
https://www.britmodeller.com/forums/index.php?/topic/235086057-hms-yarmouth-f101-frigate-1700/
OC.
Current builds
Completed works.
Thanks for the kind words Lt. Biggles and Hubac, really appreciate it :)
OC.
Thanks OC - that guy does fantastic work!  Here are two youtube videos that show what goes into models of this side (both Bismarcks, but the first guy I believe has done a number of other 1/700 scale ships):
Incredible  work  that  most of us just stand  jaw on the floor  shaking our heads at.
OC.
Current builds
Completed works.
5 hours ago, RGL said:
Mate, 1/700 is insanity!!!!
Agreed! {chuckle}
Quote:
Ditto. Gave it up as my eyes have deteriorated, but that should be fixed, come March. Hopefully. Love the range of ships, but super-detailing them is a distant dream.
Ken
Started: MS Bounty Longboat,
I think with a good Optivisor, seeing is not the problem - at least for me right now.  It's really manipulating the photo etch.  There are times when I need to use two tweezers - one to hold and one to bend.  On the last tower I built, a couple of the leg pieces were intended to be bent the long way to get sort of a V.  It's almost impossible when each of the two sides of the V are 1mm or less in width.
In any event, I'll probably try to get through my stash in the next decade as the manual dexterity and vision won't be getting any better.
Nice build, but when I look at the scale and at the PE ... I know RGL is right!!! Good luck, don't break your magnifying glass
Edited by cog
Carl
Thanks guys!  I decided to continue with the insanity a bit more last night in putting together the 12.7cm anti-aircraft gun at the bow and the twin 12.7cm AA gun at the stern.  The bow AA gun was fairly easy to put together, with two PE side pieces and replacing the out of scale barrel with a piece of 0.3mm rod.  Looks like I did a crappy job gluing the left side piece on a few months ago, doh!  But it's only about 2mm wide (if that) so I won't beat myself too much even though at close magnification it is disappointing.
The twin AA gun was a little bit more of an in-depth project, with 11 pieces to be assembled:IMG_0606.JPG.5423a20f46f31d5dfb6c7d8ee81c9e07.JPG:
Took a while, but I think it turned out pretty well.  The kit part isn't bad at all, but I think the aftermarket gun looks to me to be a bit more in-scale:
And here is how the full ship looks.  With the AA guns, it's starting to look like a destroyer :)
