Looks great Ben. Glad to see you back at her!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks for the reply re: treenail and plank sizing, Ben.
I am trying to better appreciate why and when various size treenails are employed.
Found a wooden ship building book dated 1919 with guidelines based on tonnage and joint location for treenails and bolts but not sure it hadn't changed from a century or two earlier.
Edited by AON
typed 1912 but it was 1919
Alan O'Neill
Tedious but will pay dividends to the final look Ben - nice work on the planking.
cheers
Pat
I enjoyed reading the build blog to this point!
I'm new to wood ship modeling and am working on my first kit, the HMS Terror. Someday, I'd like to try a scratch build... not yet!
I am curious about TFFM... What does that stand for?
As I continue to learn and build a tool inventory and more importantly, confidence in my work, I would like to eventually try a build from scratch.
Thanks in advance for the info!
Edited by LyleK1
Lyle
"The only thing that stays the same is the constant state of change"
Completed Builds:
Occre HMS Terror - https://modelshipworld.com/gallery/album/2065-hms-terror-occre/
NRG Half Hull Project - https://modelshipworld.com/topic/23546-half-hull-project-by-lylek1-nrg/
1:130 1847 Harvey - https://modelshipworld.com/gallery/album/2125-1847-baltimore-clipper-harvey-1130-scale/
Scott Miller's Sea of Galilee Boat https://modelshipworld.com/topic/29007-sea-of-galilee-boat-by-se-miller-120-scale-lylek1/
In progress:
Artesania Latina HMS Bounty - https://modelshipworld.com/topic/26817-hms-bounty-by-lylek1-artesania-latina-148-scale/
Waiting for dry-dock space:
Model Shipways - USS Constitution
Master Korbel - Cannon Jolle 1801
A Scratch build -TBD
Hi Lyle,
TFFM stand for “ The fully framed model” which is a set of 4 books written by David Antscherl and Greg Herbert and they are available from Seawatch books,  who are one of the sponsors of Model ship world and you can find a link to their site on the main page.
The set of books is an excellent reference for many things in model ship building and in my opinion a must have for any serious model builder looking to move into scratch building.
ben
Thanks Ben!
I'll take a look at them!
Lyle
Completed Builds:
In progress:
  • 3 months later...
Thanks Druxey,
I just wish I could live up to yours and Greg's standards for a build! I am trying my best to get better every time - and this is the best I can do so far! Spectacles are now are part of my life!
ben
Great workmanship and shop Ben.
Rusty
Hi and Thanks,
To answer your question Hubac, the Swan class is quite a small ship at 96'7" long, and at 1:48 that equates to a 24" model ( length of main deck as per normal convention ), but if you rig her which I have not quite made my mind to do but I am leaning that way it will be quite a bit bigger, but still in the realms that the display case would not be too massive.
ben
First - thanks for all the likes everybody.
So I machined all of the 22 deck beams out of 9” stock with the correct roundup of 6” and here you see them temporally installed using T-pins in their correct locations.
I also had to make the wing transom knees ( these are a pain to fit ) so beams 21&22 could be made.
Now I came across an error I made back when building the lower deck, the distance between the beams 6&7 ( fore hatch ) are too far apart because I didn’t follow the Pegasus plans but instead the TFFM plans, lesson to be learned here - Always follow the drafts of the ship that you are actually building!! I have decided to make the upper deck match the lower deck so Pegasus will end up with a larger fore hatch than she should - hopefully it won’t interfere with anything else as it is beam 7 that is too far aft.
I need to make the upper deck hook, riding bit pins and topsail sheet bit pins and get them located properly before carrying on.
ben
She looks sweet.  It is fascinating/annoying how many differences there are among the Swan class ships.
Toni
Member IPMS
                           Utrecht-1742
Riding Bitts are completed and temporary in situ, I decided to show the full length cleats between the upper/lower deck beams. They still need final sanding and finishing to complete later.
Now onto the next set of bitts.
ben
