Licorne 1755 by mtaylor - 3/16" scale - French Frigate - from Hahn plans - Version 2.0 - TERMINATED
Hi Mark! That's a nice stern you've got there! I look forward to seeing more!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
Share on other sites
Mark,
a very nice and harmonic looking stern portion, lovely work...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
WELL DONE MARK!!!!
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Link to comment
nicely done stern Mark!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Very nice work Mark!  I love that silver maple you used, really sets it apart.  btw - 1 mm off?  The Dutch would say pffffff.  ;)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Thanks for the "likes" and comments.
When I laid the keel, I also cut the stem, the stern post, and the rudder from the same chunk of wood.   I've been busy with other things recently, but did spend a lot of time researching the rudder and sorting things out.  I found that many of my assumptions and some of what is on the plans wrong.
Here's what I've found (including from those responding to a post on this)...
1) As built in 1755, there's minimal vertical taper.  It wasn't common to do this, but not uncommon either.  Which makes me wonder that maybe it was a shipyard decision.   The rudder follows this.
2) There is no fore and aft taper to the rudder.  That one caught me by surprise.
3) There is a cavitation/turbulence groove.  This would have been added when the ship was rebuilt/overhauled at some point later in time.  It would have been present in 1778 when captured.
4) The fore side of the rudder was beveled at about a 45 degree angle.  The pintle and cudgeon<SP?> straps were recessed only at the fore side of the rudder and at the aft side of the sternpost where the straps bend to the side.  They were recessed as on some other nation's ships.
5) No spectacle plate.  There's an eyebolt with rings on each side just above the strop hole for the emergency steering.  The strop hole is nominally rigged to two eyebolts.
So.. I machined the rudder blank as shown in the pictures below.  There's two mortises in the top of the rudder, one for the normal tiller (which on Licorne is in the Great Room) and one for the emergency tiller which is on the quarterdeck.
I'm off and running with the metalwork.  I've started silver soldering and wondered why I didn't do this years ago.  It's pretty fast and gives a nice result.
Link to comment
Hi mark
Nice machining and research on the rudder, would it not have been made out of three or four pieces though like the English style, the rudder on syrius appears to have actually had five pieces with the fore and aft bits softer wood in case of damage and easy replacement
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
Hi mark
Paul
It was actually made out of 3 pieces of wood, Paul.   The main piece was oak and the other two were pine.   I'm planning scribing the lines in as they're straight and not tabled like the English ships.  Unfortunately, I don't have anymore of the original boxwood that used when I cut the blank otherwise, I would re-cut.   What I do have is noticeably different so... for eye-appeal, I'll go with what I have.
Link to comment
very nice..........good to see your making sawdust.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Very nice work Mark and yes, sometimes we have to do whatever it takes to make things appear as if it's buildup out of different pieces.  hen all he smoke clears it wont (hopefully) not be noticeable.
Cheers,
                       VOC Ship Surabaya
Link to comment
The "likes", comments, and questions/challenges appreciated.....  :)
So... pushing the envelope...
I've reworked the rudder and added some metalwork.  It looks a lot better.    The metal banding will have the appropriate amount of nails in it before this piece is ready to mount.
Edit:  I forgot to add... I cut it apart using a thin jeweler's saw and then glued it back together using some colored glue.
And a couple of quick shots of the rudder irons/straps in work.  I started by annealing the straps.  I silver solder the tube, cut-off the excess, and clean it up with a file.  For the pintle, a 1/16" brass rod will be epoxied into the tube.  The cudgeon will not have the shaft, naturally.   ;)
I should note that these are not cleaned up yet.
So far, so good.  I've got a pile of brass pieces now pickling in some vinegar.   I'll rinse well and let dry overnight.  I'm thinking of using paint on these or hitting the local gunshop tomorrow for some Birchwood Casey's.  In testing, Blacken-It did nothing for the silver solder.  I've got some discards painted and drying and I'll how they look.
Edited by mtaylor
Link to comment
Hi Mark
Too much to read for too less time....................
But I`m tryin`! What I`ve seen yet, impresses me, best work. I`ll keep on watching this :) .
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
Link to comment
Your rudder is looking great Mark!
-Elijah
Current build(s):
Completed build(s):
Member of:
Link to comment
Nice work Mark, looks good
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Link to comment
Wow Mark. Very nice work!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
rudder looks great Mark  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
That's a beautiful rudder Mark.  Very nice job.  I'm about to take up silver soldering too - glad you are finding great results from it.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Now that's using your nagen on the rudder Mark.  Nice clean straight cuts, well done!  Yup, my jeweler's scroll saw is in hand's reach too, very useful tool.  Nice work on the metal straps.  Wasn't there a post where someone used blackening stuff that also blackened silver as well as soft solder?  Paint works fine with the proper prep.
Cheers,
                       VOC Ship Surabaya
Link to comment
I have found that silver solder blacken when properly cleaned and prepped.  Silver soldering is something I am glad I learned.  Just practice and after awhile you will never look back.
David B
Link to comment
Thanks for the likes and comments.
Just a few shop notes... the metal bands at the top are black construction paper. Even though they will be hidden, I just wasn't getting the look I wanted from brass.  I still need the nails.
Ah silver soldering... I'm still working on the rudder straps.  I made about 30 of them and discarded all but the best ten.   I'm happy with what I kept but I should probably practice some more.   I tried some Blacken-it I had lying around and when it hit the silver solder it put a green sludge down.   So tossed the Blacken-it and the test part.  I've ordered some Birchwood Casey Pewter Black... they say good for brass and solder... If that doesn't work, I'll paint them with some flat black primer.  Primer has a bit of texture.  I'll need the blackening anyway when it comes time for cannon but that's a ways off yet.
Link to comment
Nice work on the rudder and soldering Mark... looking really good!!!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Link to comment
Link to comment
Hello Mark,
Your Licorne is looking wonderful. You can say what ever you want. The British might have the most strongest and successful sailing vessels, but the French ships have the most beautiful lines, isn't it?
Daniel
Cheers,
Daniel
In dockyard: HM Colonial Schooner for Port Jackson (scratch), HM Armed Vessel Bounty, HM Cutter Sherbourne
Next builds: HMS Victor 1797 & Gannet 1814 Cruiser class sloops, ship and brig rigged (scratch)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
