I can imagine your initial disappointment, only six, so you must have been thrilled to bits when you found out there were more ... a lot more! Nicely done though. I would expect the different ways of building would make it somewhat more interesting ... less production line like ...
Edited by cog
Carl
Danny,
It is an absolute pleasure to travel thru your build. Your skill set (as some other modelers) to work at such a small scale is truly amazing. The final results are stunning. My hats off to one of the masters. This Fosters is for you.:cheers:
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Thank you Carl and John.
The last two ship's boats are of different construction again. The hulls are made from thin (0.12mm) paper, with the inner and outer skins glued together before shaping and gluing the two halves along the keel :
The interiors and keels were then fitted. These two boats hang from davits. I made them from 0.6mm and 0.3mm brass wire and then painted them :
For ease and accuracy of fitting the davits to the boats I made a jig :
Two straps are used to secure the boats :
The boats and davits finished :
Continued in next post ..........
Cheers, Danny
......... continued.
All the boats, with the exception of the one already fitted to the deck :
The boats fitted to the deck :
I'm going to re-fit this launch. For some reason I missed the marks when gluing it down :
Danny
Cheers, Danny
Great work on the boats Danny, they look great.  Could you fix the tiller by cutting off the squared extension and replace with some brass wire/rod of suitable scale?
cheers
Pat
cheers
Pat
No, not really. The tiller is actually square for most of it's section. It's only 1mm thick, so rounding it is not an option. It looks a LOT better in "real life" :). Besides, the boats are already fitted to the deck, and removing the rudders would be a major task.
Danny
Cheers, Danny
Danny,
Am interested in trying one, small scale is intimidating for me, all I can do is attempt if I screw it up we will watch a Viking Funeral.
My question is you appear addicted to these paper models did the bug bite you on the first one your into to it big time, after seeing yours and what Doris has done there fantastic. Never thought of paper medium could render such a fantastic builds (stupidity lurks in the dark recesses of the mind).
John Allen
On deck
Finished
John,
The 1/200 scale of Danny's Hood model is common, but there also many kits available in 1/100, especially from the J F Schreiber company. In addition, any card kit can be scaled up or down using a scanning printer/copier. This is actually a fairly common practice in the card modeling world.
It sure did :). It looks like I'll be sticking with paper for a while yet. Plus the fact that I don't need as much workshop space for working in card, which is a bit of a consideration in my current circumstances.
A bit further to Chris's comments above. Ships aren't the only things you can model in card. You think of it and there's some kind of card kit available - planes, tanks, rail, buildings, cars, motorbikes, furniture, the list is nearly endless.
Danny
Cheers, Danny
Danny
And some of the "other" card models I've seen have been phenomenal. Aircraft and armor models in particular.
superb job on the ship's boats Danny........a major step all in their own  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you guys :).
There are a LOT of small details on the main deck. Whenever I come across a "new" part that has more than just the one piece I'm making them all at once and storing the remainder for future fitting (on the other side of the hull probably). Everything except the rigging is now fitted above the main deck. Here is a selection of details :
Danny
Cheers, Danny
A couple of pics of the finished upper decks. Railings hadn't been fitted when I took the pics, but they are on now :
Danny
Cheers, Danny
3 hours ago, Dan Vadas said:
Thank you guys :).
Danny
Superb work,  I love the detail of the (possible killer area for her - T tubes)  when she met her doom.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
seriously nice work Danny.......the deck is pretty busy :)     high level of craftsmanship there.....WOW!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks John, OC and Popeye :).
The return hawse for the anchor chain is one of the trickiest parts to cut and roll on the whole model, mostly due to it's small size :
The Anchors took me a full day to make, and I'm pretty happy with the way they turned out. Here are the parts for just one of them :
The shanks and flukes under construction :
The finished anchors :
The rest of the small details on the starboard side foredeck. I've since added the port side as well, which completes all the parts for the decks and superstructure with only the deck railings to go :
Danny
Cheers, Danny
The Rigging only took a day to do, and it's turned out the best of any Card model I've done to date :) :
Danny
Cheers, Danny
Stunning work as usual,   she is going to be such a museum quality exhibit when finished.
OC.
Current builds
Completed works.
19 hours ago, cog said:
Your rigging looks good. What did you use for thread?
It's an elastic thread from Ez-Line. I tie it with a simple overhand knot at each end, put enough tension on the line for the particular application - tighter for those lines that have another attached to them so they don't get pulled out of shape - and finish off with a tiny drop of CA glue.
Danny
Cheers, Danny
Thank you Grant :).
The Screws (propellors) are of similar construction to those in my Amatsukaze kit, also by Halinski - lots of petals, which means lots of careful cutting. I shaped the central piece using a rounded stick on high-density foam :
Four hours later :
And finally the completed units. I used a thin wash of acrylic to soften the dark colour of the seams :
I've started the main deck railings, and also made and fitted the port side entry ladders. The railings were designed for a plastic (Tamiya) kit and don't fit perfectly in regard to positions of the ladders, bollards etc, so some fudging is needed :
Danny
Cheers, Danny
catching up on the fantastic work you've been doing.........I'm in awe!   the rigging looks great and the deck fittings are as well.   I've always known the anchor hawse,  as a chain gate.   are the boarding ladders on even when the ship is underway ?   I've got 'em for a couple of my builds,  and I'm not sure if I should add them or not.   I also thought they were removable.
first rate job Danny!   really nice work  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
