Wow, it looks easy as Lego ... except if you tried to make anything of wood ... then you realise what kind of SF is presented here
Extraordinary, inspirational and educational work
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Thanks Danny, for your suggestions on planning my new workshop! You clicked on a few very practical ideas I had not considered.
Your build is amazing. Very nice work. I agree with the others, the degree of detail makes the model look like a larger scale.
Model(s) under construction: RATTLESNAKE. 1:48
Next on the launch : ECHO 1781 1:48
This Index continues on from the one on Page 1. To return to the first Index click HERE
Head Works
Lower Cheeks
Hair Brackets
Wash Cants
Bolsters
Gammoning Chocks
Main Rails
Head Beam and Grating Battens
Head Timbers
Saddle
False Rails and Aft Seats of Ease
Cathead Supports
Eking Rail
Gun Port Lid
Bridle Port
Figurehead
Masts
         Deadeyes
         Chains
Preventer Plates
Lower Masts
Mast Cheeks
Bibs and Trestle Trees
Cross Trees
Bolsters
Starboard Side Black Strake
Iron Work in the Head, Spanshackle Ring and Fish Davit Cleats
Wooldings
Forecastle Railings
Berthing Rail
Billboard
Mast Heads and Caps
Topmasts
Topmast Trestles and Crosstrees
Topgallant Masts
Cheek Blocks
Bowsprit
Hearts
Standing Rigging
Collars
Bobstays and Bowsprit Shrouds
Gammoning and Boomkins
Fore Tack Step Blocks
Main Stay Collar
Mizzen Mast Shrouds
Mizzen Mast Forestay and Collar
Main Mast Lower Shrouds and Burton Pendants
Fore Mast Shrouds
Main Stay
Main Preventer Stay
Fore Stay and Preventer Stay
Mast Tops
Making Blocks
Blocks under the Tops
Top Stanchions and Railings
Catharpins
Euphroes
Crowsfeet
Futtock Shrouds
Ratlines
Shroud Cleats
Mizzen Topmast Shrouds
Mizzen Topmast Stay
Main Topmast Shrouds
Main Topmast Stays
Topmast Futtock Staves, Fore Stay and Preventer Stay, Topsail Yard Tyes
Topmast Ratlines
Topgallant Shrouds and Stays
Jibboom Crupper and Jib Traveller
Jib Net
Jibboom Horses
Fore Topgallant Stay
Jib Stay
Mast Trucks
Yards and Running Rigging
Spritsail Yard
Jeer Tyes
Topsail Sheet Blocks
Blocks fitted to the Lower Yards
Stunsail Irons
Truss Pendant Tackles
Spritsail Running Rigging
Crossjack
Mizzen Mast Cleats
Gaff
Jeers
Yard Lifts
Main Stay Tackles
Topsail Yard Tyes
Parrels
Topsail Yard Lifts
Topgallant Yard Parrels
Vangs
Braces
Lantern
Anchors
Fish Davit
Swivel Guns
Waist Rails
Hammock Cranes
Anchor Rigging
Clues, Tacks and Sheets
Fitting Hammock Cranes
Fitting Swivel Guns
Flags
Fitting Stern Lights Part 1
Fitting Stern Lights Re-Do
Fitting Capstan Bars
Pedestals
Rope Coils
Lantern Braces
Binnacle
Cheers, Danny
Gun Port Lid
There is only one gun port lid on each side of Vulture - the aftmost one, or Number 8, which is in a cabin. With the exception of Number 1 which is in the Forecastle the others are all more or less open to the elements and don't need them. I'm surprised that Number 1 port doesn't have one.
I'm rather glad I didn't build a Victory - I'd have needed to make a few more ;) . This one port with it's hinges took me three days :huh:  . The only other port I'll be making will be the port side Bridle Port, it's a little bit easier as it doesn't have as many eyebolts and rings. No port lids will be fitted to the open starboard side.
I made the hinges from a piece of 2mm thick brass strip, and incorporated the knuckle into it by filing rather than soldering a separate piece on (I've run out of suitable tubing). The majority of the work of removing the surplus was done with the disc sander, the rest with needle files. I drilled the holes for the bolts and the hinge pin just after tapering the top face, while the piece was still attached to the rest of the strip. This made clamping to the mill vice easier :
The Hooks (the other part of the hinges) were made in similar fashion. I silver soldered the pins to them after first drilling holes for them :
The Port Lid itself was made by cross-laminating seven pieces - the external face has three and a bit planks which follow the run of the hull planking, and the internal face has three planks which are fitted vertically. After blackening the hinges they were epoxied and pinned to the lids. I used 0.8mm round-headed pins (shaft diameter of 0.4mm) :
Eyebolts and rings are fitted both inside and outside for the port tackles - these will be faked as there is no way that they can be fitted at this late stage of the build :
The hinges REALLY WORK :D :
I'm off to the Port Macquarie Model Show in the morning - I've got Vulture almost exactly to the stage I'd planned on a couple of months ago for this show :) .
:cheers:  Danny
Cheers, Danny
Danny
Wouldn't it have been quicker to order a piece of tubing and soldering than sanding and filling :rolleyes:    Disk sander or not, that is a LOT of material to remove.
I must say they do look very very good.
Allan
Those are good-looking pieces of hardware, Dan, but that was a lot of work! Good luck at Port Macquarie.
Danny you are a either a nut or a masochist. :)  That is a ton of work.  But the ends justifies the means beautiful work.
David B
Edited by dgbot
Have fun at Port Macquarie. That was an interesting method of making hinges but they turned out beautifully.
My admiration to your masterpiece and professionalism. Looks outstanding!
Best regards
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Lovely work Danny . One of these days I'll make time to go to one of those model shows in NSW and get a good look at your masterpeice .
My sincere apologies for not posting sooner - my computer was either very sick or dead these past few weeks - all fixed now :) .
Thank you for your replies Allan, Druxey, David, Mark, Doris, David, Crackers and Johann, much appreciated.
Of course it would have Allan (and David B), but you must have missed my comment regarding that bit - I didn't have any tubing of the right size, and to get some would have meant a 1 hour round trip with no certainty of success in getting any from the "local" hobby shop :( . I figured correctly that I could file the hinge straps in about the same time :D .
Deadeyes
Although my computer has been down I haven't been idle. I've turned ALL the Deadeyes and drilled them as well - all 142 of them, in four sizes - 64 off 10" (real size) or 5.3mm, 20 off 8" (4.25mm), 42 off 7" (3.7mm) and 16 off 5" - a tiny 2.65mm, the holes were a lot of fun to get right in these ones :D .
First, an explanation of why I made my own when there are very good quality ones available from companies like Syren Ship Models and some of the Russian sites. While these are of very nice quality, none of them had them in the sizes I needed. For example Chuck supplies all of his in even millimetre sizes (with good reason) and I thought the differences in some of the sizes I needed would have been too great and noticeable. For the 8" and 7" deadeyes I would have had to go with a 4mm deadeye for both, as you can see from the previous paragraph. The 5" deadeyes would have been either too large or too small.
Besides - I like a challenge :D .
After turning the diameter of the "huge" 5.3mm deadeyes I used a 1mm Parting Tool to cut the groove and also part it from the stock - the Digital Readout came in very handy to keep them all to exactly the same dimensions. For the 7" and 5" ones I ground an old parting tool down to 0.7mm. I rounded the edges with a needle file :
To drill the three 0.6mm holes for the 10" and 8" ones I used my new Rotary Table in the Mill. The holes are 1/4 of the way in from the outer edge and are spaced evenly at angles of 120 degrees apart. The 7" and 5" deadeyes have 0.45mm holes :
All the deadeyes separated into sizes :
An idea of the small sizes of them. Some 10" and 5" deadeyes on top of a 5 cent piece :
:cheers:  Danny
Cheers, Danny
Thank you Brian and John.
PS The five cent coin is 19.41mm in diameter!!
Which means I can fit 7 of the 5" deadeyes across one and still have room to spare :D :
Chains
Construction of the Chains - the "support braces" for the lower deadeyes - begins with the Upper Link or Deadeye Binding. As it's name suggests this is a forged steel binding which wraps around the deadeye. It passes through the channel and has a loop in it's lower end which attaches to the Middle Link.
To make these, which are all the same for this size of deadeye, I used a jig. The 0.7mm brass wire was first bent into a rough oval and the join silver soldered. Then it was tightened around the wooden pin and nail with needle-nose pliers to form it's shape :
The wooden peg in the jig was turned down to give a push-on fit over the outer diameter of the deadeye. Final fitting was accomplished with needle nose pliers. I needed to make one up to measure the following links - this one was later opened up and the deadeye removed prior to blackening of the wire :
Continued next post......
Cheers, Danny
How come that silver solder looks like soft solder? Beautiful job on the dead eyes not only did you drill a lot of holes but you did a lot of spinning of that rotary table as well.
Michael
..... continued.
Thanks Michael. I use a mini gas torch for all my soldering, and silver solder paste. It flows beautifully, but the joins MUST be a zero fit as it won't fill any gaps.
The Middle Links and Lower Links were both made by first cutting all the pieces to length - oddly enough ALL the links finished up the same length of 28mm, even the upper links. According to TFFM the middle lengths should have been of varying lengths to allow for the change of angle, but as they also sweep up slightly as the go aft the difference was so minimal (0.2mm) that it didn't warrant a whole lot of extra work ;) .
To bend the pieces I used a simple two-nail jig. The lower links were then silver soldered and shaped around a 1mm drill bit at their lower ends. The upper ends were finessed with pliers around a wedge shaped piece of brass held in the vice similar to the one shown here :
The three links ready for final fitting :
Once the lower links were soldered and shaped the middle links were fitted between them and the upper links and soldered together. The middle link was then tightened down using the jig shown above :
I use a piece of pumice stone ($4.00 from a supermarket) to hold the pieces for soldering.
:cheers:  Danny
Cheers, Danny
beautiful work Danny,
the making of the deadeyes in Wood and brass Looks very nice. The torch heated Joints with silver solder are very well done. Thanks for sharing that pic sequence
Nils
Current builds
-Lightship Elbe 1
Completed
Great work Danny, and thanks for sharing your methods again. There is always so much to learn from reading your log ! :)
Thanks for the explanation Danny.
Michael
Lovely work all around, Danny.  Thanks for showing us how the chains are done.
Thanks once again for the kind comments Geoff, Nils, Grant, Pat, Michael and Mark :) .
Here's a pic of a completed deadeye with chains. The deadeye was fitted after the chains were soldered and blackened by clamping the deadeye in the vise and squeezing the upper link tight with needle nose pliers :
I've made all the various size deadeye/chain assemblies. The last of them are pickling in vinegar at the moment, prior to blackening.
Preventer Plates
I've also made the 32 Preventer Plates, which fit to the lower end of the lower links on the Fore and Main shrouds. The plates were made by drilling the 0.6mm holes 7mm apart in a strip of 3mm x 0.8mm, and then filed to shape. A line was marked between the holes to simulate the way they were originally made - the piece was forged from square bar on the original.
A dog-leg was then bent into the upper end to give clearance for the chain from the hull. I made a simple jig by taping a piece of 0.8mm plate to the top of my small anvil. Another thicker plate was then placed over the piece and tapped a couple of times with a small hammer to make the first bend, then the other bend was tapped in by hitting the end of the piece :
:cheers:  Danny
Cheers, Danny
Nice metalwork Danny, you fooled me into thinking the plates were forged together ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Hi Danny,
I love the way you do the selfmade Fitting out rigging parts, probably many thoughts and Prior Trials went into the parts manufacturing, until they meet with your satisfaction, well done !
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you for dropping in again Remco, Nils and Ben :) .
Lower Masts
Sometime soon I'm going to need the Masts for alignment purposes to go ahead with fitting the deadeyes to the channels. Up until now I've "made do" with a couple of "dummy" masts, but now it's time to make the real things :) .
I was lucky to buy one of the last of the Masting Packages for the "Swans" from Hobbymill about a year or so ago. As usual, Jeff's timber and packaging is EXCELLENT - there are TWO pieces supplied for every part needed in case of "oopsies" (I've already made one :D ).
The masts (and just about everything else) starts out as square stock - no dowels in this lot, that would have been counter-productive :D . Following usual practice for making "round" masts from square stock I marked out two sides with the taper required. I've also tapered the masts below deck as per the original. The pic below shows the marking out for the section between the Partners and the Heel :
After tapering these two faces with a chisel and sandpaper I marked out the other two and tapered them as well. Then I marked out each face for the edges where the "octagonalling" would finish. I cut the tapered square section into a tapered octagon using a "V" jig and a sharp chisel :
Then I rounded the octagon using a sanding block, and cut the lower tenon into it :
The Mast Head remains square for now - much more work to be done here later :
Fore and Main Lower Masts fitted to the ship :
Note - I had to make two Main Masts (the oopsie mentioned earlier). I'd made the main mast a bit too thin at the partners on the 1st one and wasn't happy with the result. Just as well that Jeff had supplied plenty of timber :D .
:cheers:  Danny
Cheers, Danny
Danny I just realize it's been way too long you've show an overview picture of your Vulture. You always have been showing all the details but I was stunned  (but not surprised ;)) to see how beautiful everything is in the overview shot above.
I can only say 'please show me more!'
re: the masts, you'll find that lots of fun.
Remco
Edited by Remco
Danny
I like the varying vee block set up.  Are there just the two we see in the photo or do you have more to support longer pieces so they do not bend during the chiseling process?   I am very happy to see you demonstrate that a sharp chisel can do wonders, and dowels are not necessary to make masts or spares.
Allan
Thank you Remco, John and Allan.
OK Remco - you asked for it :D :
There are four supports Allan. They work fine at the moment, but as I get into the smaller sizes I'll remove a couple of them and replace them between a couple of the existing ones. BTW - this jig came with the Masting Package.
:cheers:  Danny
Cheers, Danny
