No he's not ;):D.
:cheers:  Danny
Cheers, Danny
Very nice work Danny! She looks fantastic!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
the turrets look super Danny........great progress ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks guys :) ,
I've been really crook the last week or so - the worst case of Flu I've ever had the misfortune of having :(. Fortunately the symptoms are on the way out, and I can continue building. Only the runny eyes are a bit of a handicap, but hopefully they'll clear up shortly :).
I've managed to finish the three Gun Turrets, despite my woes. The instructions were rather vague about how the turret Pivots went together, and I'm not sure if they are meant to actually pivot or not, but I worked out a way of doing so. Here's the diagram - I've fitted part 100b BETWEEN 100d and 100e :
And here are the parts cut out for one pivot. I've already glued on the edging bands to the two larger discs :
The main "working" parts of the pivot. The disc 100b needed a lot of dry-fitting before establishing how far "up" the axle 100a it needed to go to get the right clearances :
Top and bottom views of the assembly fitted together. Discs 100d and 100e are glued together. Care had to be taken not to get any glue on 100b/100a :
The pivot glued to the base of the turret, along with four gussets. Not shown in the pics is a small stub of 1.0mm brass wire in the centre of the pivot. This will locate into a corresponding hole in the deck to make later fitting much easier and more accurate :
The last of the wire work on the turrets is what I assume to be a small antenna :
And finally I've fitted the gun barrels. Note the working barrel elevators :
:cheers:  Danny
Cheers, Danny
1 minute ago, Canute said:
Glued joints or what for that "antenna"? Sort of looks soldered.
Thank you both :). I used CA glue - my soldering torch has decided to stop working :(.
:cheers:  Danny
Cheers, Danny
Sorry to hear you've been under the weather Danny - there's been some really nasty flu bugs going around this year. Glad to hear you're on the mend though. And the build is looking outstanding!
The turrets look great Danny, well done.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Always known you were the sensitive kind ;) As long as you don't drip on the card it doesn't matter to much ...
Love those turrets,  very detailed with the PE parts/brass wire.
Carl
guess it doesn't matter what the definition of 'DNA' gets on the parts.......we all seem to leave our 'Dinty Moore' somewhere or another ;):D   glad to hear it wasn't anything serious Danny.   do the barrels move up and down?   always hated it with plastic modeling.....darn things usually ended up loose.   I'm sure paper would tend to offer some sort of resistance.   they look really good....wonderful job on them!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks all for the kind comments :).
Yes indeed popeye, they will also swivel. Both "directions" seem to work very well indeed :).
Moving along to one of the last major sub-assemblies - the Torpedo Tubes. These are made in a similar fashion to the gun turrets, except for the tubes themselves. The pics should be fairly self-explanatory. I used my new large hole punch to make the 3.4mm holes for the tubes in the turrets :
I tried two "methods" of doing the railings, one using 0.2mm hard brass rod for the rails, the other using the same size in soft wire. The soft wire was far easier, and there was very little difference in the outcome :
:cheers:  Danny
Cheers, Danny
Nice work Danny, she is coming together very nicely.
Do you finish these card models off with a coat of lacquer? I ask as paper/card does not have the longevity of wood and wonder how long they will last without some preservation.
cheers
Pat
Thanks Pat. Yes, two or three coats of Testor's Dullcote usually does the trick as a finish. I also give the card two coats of Mohawk Nitrocellulose Lacquer before I start cutting anything.
:cheers:  Danny
Cheers, Danny
Apart from painting the rails the Torpedoes and their Turrets are finished.
The torpedoes are rolled as a solid tube so the ends can be rounded. To make it easier to sand the round end I used a French Curve to cut the warhead end :
The tail ends are a cone. I bought a Forming Tool from RP Toolz which did the job very well :
I dipped the warhead ends in CA to stiffen the paper, and then filled and sanded them to shape :
Although they can't be seen I fitted the fins to the torpedoes. This made them easier to slide into the tubes :
The Air Pipes are made from 0.5mm tubing and 0.3mm wire :
The finished Turrets ready for final painting. The Swivel Mounts were made in similar fashion to those on the Gun Turrets :
:cheers:  Danny
Cheers, Danny
nicely done!   they will look super with the finish work done on them ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks John, Clare and Popeye.
The Torpedo Turrets are painted and finished :
There are two Ships Boats. These proved a little difficult to make, and I'm not 100% happy with them, but they'll have to do. Apart from one picture of a finished boat there were no instructions at all.
I started by gluing the bow together, then adding the forward platform :
Next I glued the keel together, and also added the transom :
The flooring pushed the skins out to the correct shape :
Then I glued the last of the cuts in the skins together, glued in the aft platform and thwarts, and finished by attaching the keel/rudder unit and the storage chocks :
:cheers:  Danny
Cheers, Danny
Nice job on the cigars and their cases, Dan. It seems you finally get a challenge on the boats, although that seems to be a piece of cake to you as well ...
Carl
Thanks for the kind words Carl, Bob and Jan :).
The two Motor Launches were a little easier to make, mostly because they have "steel" hulls instead of "clinker" ones and could be touched-up. The design was also a bit easier to work with. Here's a series of pics that follow the construction :
The launches completed :
I've also made the Depth Charge Launcher. This had a few rather small pieces, the largest tubes (the depth charges) are only 1.6mm diameter :) :
:cheers:  Danny
Cheers, Danny
More progress. I've made and fitted the Anchors. These required quite a bit of delicate cutting :
The Depth Charge Rack was fairly straight-forward apart from the two small cranes :
The Searchlight took me a full day to make, mostly due to the Bracket - gluing it together could only be done one section at a time. The first pic is of the parts needed for it :
I also fitted a ladder, the RDF antenna and three railings around the searchlight :
The AA Guns and the forward Torpedo Tubes were fitted next :
Last I fitted two inclined Ladders and the railing to the aft end of the foredeck. It would have been a lot easier if I had painted the ladders before fitting them :
And here's a Progress pic of where I'm up to. The funnel assembly has been permanently fitted :
:cheers:  Danny
Cheers, Danny
