HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Danny
I`m absolutely with Adam...
As you probably recognized, I`m taking a Little pause on my own P.Sue build, but seeing your fabulous work in process really encourages me....to get further going on it again
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks John, Christian, Ben, Adam and Nils :) .
I've finished fitting the Channels, Standards and Drift Rails to the Port side :
Quarter Badge Crown
I've also carved the Crown for the Upper Finishing on the Quarter Badge. It's certainly not up to the standard of some of the great carvers on this site, but I'm happy enough with it. Here are some pics from the rough-cut blank to the finished article. I used English Box - it took me about 3 hours work. It measures 6mm wide by 4mm high :
:cheers:  Danny
Cheers, Danny
That is some super fiddly work at that size and it came out looking great, Danny.
Thank you Mark, John, Druxey and Pat. The puns are flying thick and fast today :D . Thanks also to all those who have been using the "Like" button.
Main Studding Sail Boom Irons
There are two pieces of ironwork attached to each main channel. One of these is an Eyestrap, into which a pin on the inboard end of the Main Studding Sail fits allowing it to swing out. The other (aft) one is a Gooseneck which holds the outboard end of the boom when it is stowed.
I made these from 1mm thick brass strip. Both pieces taper in width and thickness on the inboard ends. I drilled three holes in each piece for the "bolts", which are made from brass pins silver soldered to the straps and the heads filed square.
The gooseneck part was silver soldered to the arm, as it needed a very sharp bend which wasn't possible to do. I trimmed the brass nails to the thickness of the channel :
The pieces fitted after cleaning up and blackening :
:cheers:  Danny
Cheers, Danny
I do not know what amazes me the most, your eyes or your skills for metal parts
Thanks very much juandavid - and your first post too, that's a double honor :) .
Believe me, it's definitely NOT my eyes. My 4x Optivisor is starting to become ineffective, might be time to upgrade it :huh:  .
:cheers:  Danny
Cheers, Danny
Fenders
The Fenders assist in loading the ship, especially from a boat. Barrels could be more easily loaded as the fenders make a smooth run over the rails below :
Unlike the Chesstrees I fitted earlier, the fenders don't play any part of the rigging so I'm only fitting them to the Port side.
:cheers:  Danny
Cheers, Danny
Your metal work is both cleverly thought out and expertly executed Danny.
Danny
It will be a sad day when the work is finished, for those of us following your build.  I may have missed in an earlier post, but is rigging in the future for the Vulture?
Allan
In my opinion you should do a stubbed mast model. All of the rigging would hide all the wonderful work you have put into the Vulture.
David B
Hi Dan,
lovely looking fenders, and your metal work is incredible! Your Vulture is one of my favorites here on MSW!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Thanks again Grant, Allan, Bug, David, Guy and Alex - your comments are very welcome :) .
Allan and David - I'm intending to fully mast and rig the ship (if I live that long :D ).
Entry Steps
There are six Entry Steps per side - I'm only fitting the Port side.
To avoid making yet another Molding Scraper (which would have been very difficult to use around the ends of the steps in any case) I've made each step in two pieces using English Box. I used a previously made scraper to shape the lower portions, along with needle files and Xacto knife.
The two steps on the black Wales have been stained with Ebony wood stain - real Ebony didn't like my scraper very much, too much chipping out happened when I tried it on a sample piece :
Each step needed a varying degree of bevel sanded into it's inboard face to match the shape of the hull at that point.
:cheers:  Danny
Cheers, Danny
Dan,
I don't know, what I can write what was not written before?
It's a fantastic build and build log with lots of tips. Thanks very much
Regards Christian
And thank you shihawk, Geoff, Christian, Rafael, Spyglass and John :) .
Swivel Gun Mounts
There are six Swivel Gun Mounts on the Forecastle and ten on the Quarterdeck. They are octagon shaped on the upper portion, and square on the lower. I used a jig with a "V" cut into it to sand the octagon shapes in :
A small decorative shoulder was cut into the transitions using an Xacto blade :
The bottom is quarter-rounded. I used the Byrnes Disc Sander for this :
The forecastle mounts are all the same length, so I've made all six. The quarterdeck ones are of varying lengths, so I'll make up two at a time.
At this stage I have left the tops of the mounts a little bit long, as they will need to be trimmed to follow the Sheer line longitudinally and are horizontal athwartships.
:cheers:  Danny
Cheers, Danny
Several hours later I've made all the swivel gun mounts to this stage. Next comes some rather tricky ironwork.
:cheers:  Danny
Cheers, Danny
I'm with Remco.  That does seem to beat the heck out of setting up the mill and they look great.
Dear Danny,
I can only say - just awesome. Great looking model. Your skills are really excellent!
Kind regards
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Very nice Danny, we learn more every time we see your log, especially the use of jigs. Thanks for the updates
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
