Looking forward to the pdf file.
Respectfully
I really do love these 3D printed blocks...
Ok here is my presentation....keep in mind that I have an soft spot for Henry Culver.  He rigged so many of the Rogers collection models.   He kept it simple while making sure the rigging was not heavy and hung just right.  That is my inspiration for stropping like this.   See some examples of his work...check out those Seawatch books.  You wont be disappointed.  It certainly isnt the kitchen sink approach but it works for me.
The presentation...
Stropping Blocks (one method).pdf
On 3/9/2025 at 12:23 PM, westwood said:
Wow, if it wasn't written that it was 3D printed, I think it really is a pear with a little patina.
Thank You so much...You would not believe how long it took and how much money I spent testing to get that color and finish.  Slightly different with each block and within each block... but consistent.  With just a hint of different shading and transparency in each block. When they are too uniform and flat they look fake like most others I see on the market.  But a real wood finish isnt like that. I am quite happy with them.
Many thanks for these explanations and this superb step-by-step guide. A quick question about cyano glue. Can I use any brand or is there a specific brand that prevents the thread discoloration? In a nutshell: is it simply cleaning with your finger that prevents  discoloration, or does the brand of CA also play a role?
These blocks are really superb! Thank you for all your hard work !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
I use any brand but always the medium viscosity.  I know many hate…hate….CA glue for rigging.  But it works for
me and you use very little as you wipe it off right away.
But you could use PVA as well.  But it will take longer to dry and is problematic with synthetic polyester rope.
Chuck
Thanks for the clear and precise answer, and thanks again for the tutorial.
There's often a tendency to want to complicate things when, more often than not, it's the simplest methods that give the best results !
Jean-Paul
Current builds :
Finished build :
Next on list :
2 hours ago, Chuck said:
Some Syren 3d printed rack blocks and shoe blocks....a special project but I may make these available.
This will demonstrate my relative "newness" to the model ship world, but... never seen rack blocks before, to my recollection.  What would they be used on?  How are they used?
They do, however, look awesome, Chuck! 👍🏆
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Thank You...
This is a rack block....although a smaller one on the Speedwell.  See it just behind the gammoning.  On the bowsprit.
The testing process was long and hard before I got the results I liked.  I just spent hundreds if not thousands of dollars testing different resins and mixing them together.  Post print and pre print dye added....more testing etc.  Hundreds of man hours and print tests.  Very frustrating along the way.  Many many failures.  And of course the best results were from the most ridiculously expensive resin.
With so many new people starting to sell 3d printed blocks and other aftermarket products, my final proprietary blend of herbs and spices will remain a Syren Secret  Formula.  At least for now.
Sorry and I hope you understand.  I have been burned before.
Chuck
You absolutely should keep your process proprietary, Chuck. The time as well as cost you've invested should produce a return for you. You didn't invest in all that to produce a dozen 'me too' knock-off merchants.
As have all the good designers, sadly. You are wise to keep your secret recipe close to the vest -- just like Miss Mamie and Miss Emily.
Oh I didn't realize that's how they come out from the printing process. I thought they were painted or stained after printing. Of course that should be proprietary information.
Edited by usedtosail
On 3/16/2025 at 12:11 PM, Chuck said:
So sign up for the show if you are able to attend.
All signed up and looking forward to seeing you and this nice little project!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Sorry, but the show is a little bit far away from Germany.🤣
Regards Christian
But maybe you will get one of the 8 kits here on MSW.   I will be making them available after the CT show.   All proceeds going to the NRG/MSW
They will be priced to sell quickly....😉
Placeholder for the kit instructions of the Speedwell Battle station.  The kit will be given away at the Joint Clubs show this Saturday.  But I will be heading up a group build at out local club in New Jersey.  The goal for our small club was to create a teaching mini kit to help describe one method for doing three things.   I will also be distributing a bunch of these small kits here on MSW.
-Building a cannon carriage with a jig
-Rigging a cannon with a simplified approach
-Painting small figures for your ship models.
The last tech group tech session will require a separate set of instructions for the group to be made later.
Mono
SpeedBattleStationInstructions.pdf
Plan sheet
joint clubs.pdf
Material list
list materials.pdf
I have been asked by so many people to NOT make this a limited edition kit at all.... and because it would be a great opportunity for other local clubs to also use it as a group build.   I havent decided yet.  Same is true with doing a group project here at MSW because this is something that wont take several years to finish and it is a very quick project.   Plus it has three main points of teaching that is commonly asked about by new and intermediate builders.  Granted this is just one approach to doing them all.  But it would be interesting to see some of the other approaches.  The instructions attached contain a very detailed step by step for rigging the cannon because that was one of the main focuses for my club group build.   The kit also contains a jig for making the gun carriage.
I opened the online store yesterday and at the time was nearly fully stocked.   But in two days I have seen a huge upswing in sales....huge.  I am not sure why. Maybe the tariff situation but I really dont know.  Maybe from folks seeing the rope and blocks at the show?
Anyway,   I just want to let folks know I am diligently making more blocks and rope...but its going to be a slog.  I am down to nearly nothing left in stock right now.   I will be working as fast as I can so thank you for your patience.
The "swiss pear" colored 3d printed blocks in particular are literally flying off the shelf.  The more folks see and use them, the more I sell.   I have all my 3d printers working full tilt.  Again thank you for your patience.
Oh no! two more photos to be ripped off to sell crap blocks!
They are really nice Chuck.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Welcome back, Chuck!  Everyone knows how great your blocks and deadeyes are, so... whoosh! They're gone! 👍🏆
I was going to ask if you've ever done triangular deadeyes?
Gregg
They are on the honey-do wish list!!!  So much to do and just impossible as one person.
But yes eventually.
Chuck
Chuck, do you know if tariffs apply to any of your goods being shipped to Canada? Or, does anyone know if tariffs apply to anything model ship related being imported to Canada from the United States?
Todd
"I am always doing what I cannot do yet, in order to learn how to do it."
Vincent Van Gogh
I honestly dont know.  Because its on the buyers end I wont know until someone tells me.  So if anyone out there has some knowledge.  I think until May 4th anything under $800 is still good to
go but after May 4th its anyones guess.
I shipped a few to Canada yesterday and today so maybe will know shortly if those folks let me know.
Chuck
The current list of items can be found here:
https://www.canada.ca/en/department-finance/news/2025/03/list-of-products-from-the-united-states-subject-to-25-per-cent-tariffs-effective-march-4-2025.html
A quick skim through the list and I found the following goods pertinent to model ship building are currently subject to 25% tariffs:
•Wood strip, various species exceeding 6mm in thickness
•MDF
•Plywood
•Various tools, hand and power, knives, blades etc. (consult list linked above for specifics)
All other goods would be subject to the usual basic personal exemption in place prior to tariffs going into effect.
Since most of Chuck’s wares could be considered as “Toys or Toy Parts” they are not yet subject to any tariffs, as far as I can see from the list.
Keep in mind, as well, that the list applies only to goods originating from the US. Goods manufactured elsewhere, but subsequently sold from a US retailer would also not be subject to tariffs.
As Chuck said, more tariffs could be coming, but the Canadian government should publish any updates.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Well, LOL...you guys actually managed to do it.   I thought it would have been impossible.   You cleaned me out...literally every package of rope and every package of blocks...swiss pear that is.   At 1:45 PM I had to call it, a $620 order for rope from a great customer in Germany.  He cleaned the shelves empty of what was left. Approx. 3600 linear feet of rope.
Unfortunately this means I have to close up the store to restock.   Otherwise they literally sell out as quickly as I can make them.  I need to build up some cushion in my inventory so I dont have a heart attack chasing orders while open.  Its springtime...its beautiful outside.  What are you guys doing cooped up in the shop buying so much ship model stuff?  Get outside in the garden and enjoy the great weather, LOL.
Seriously though, thank you so much....and sorry about the delay.
I am working on it!!  Lets see, I think I am working on 5mm pear deadeyes currently and .018 brown rope...a long way to go.
I am not going anywhere and I am NOT going out of business, there is no pandemic...so I have no idea why or what seems to be happening.  Its mind-boggling to say the least.  Crazy
I think everyone is trying to stock up before the tariffs go into effect.  People around here are stocking up on cans of tuna fish (Vietnam) olive oil & pasta (Italy), etc. ABC had a piece on it this morning.
Glad to hear tho that business on your end is booming.
Edited by Jack12477
Jack
Current buildUS Constellation
I dont think so.  Most of the orders are from the USA and domestic. So it doesnt really matter.   Of the 36 orders from yesterday only 5 were international.   2 from the UK, 1 from Canada, and one from the Netherlands and one from Germany.
Yes my costs are going up for almost everything but I am trying to hold off on raising prices if at all.  I havent raised any prices yet.   Having said that...My AYC wood costs have almost doubled.   My resin costs are up slightly about 15 to 20%.  I just bought a crap ton of boxwood so I will hopefully be good for a while.  That was only slightly up as well.  Those are my biggest material costs.   Other materials are up 10 -15% on average.   Not a good thing at all.....  But my prices will remain the same as long as I can keep them that way.  At least through the summer and into the fall.  Unfortunately I have no control over the Tarif tax if you are buying from outside the USA.  Its a shame and not great for small businesses like mine.  But out of my control.
Chuck
So pleased for you Chuck to have such a “first world” problem. Long may it continue!
