Without all those frames on my build, I had no where near the sanding, but it still seemed like I was doing it in my sleep. If we gain anything from this hobby it's repair/re-work and sanding skills!
Posted this and then realized I forgot to say how great she's looking!
Edited by Sherry
Sherry
Every goodbye is the birth of a memory...
Current Build: San Felipe
Finished Builds: Mayflower Build Log
Gallery: Mayflower
Thanks for the "likes" and comments... finish sanding with the "good" paper will wait until the whole  hull is planked.  Yeah, I know, the longer I wait, the more there will be.  :)
Popeye,  I think you might be right but if it's what I think it is, it's wood that will be cut off.  The trim line is supposedly just in front of the first frame which I just re-checked and I'm good..
Anyway, need to resolve some issues at the stern.  More later.
Well, I hate to say it, but this log is now terminated. :(    I knew about a year ago that it might come this but not in the way I thought.   There's been a lot of lessons learned and I'll give some of them as they are also reasons for terminating this log.
However... I will be starting a new log on Licorne once a fresh supply of framing material arrives.  :)
Lessons learned:
1) Use only one set of drawings.  I started by using two and assumed that they were dimensionally the same.  Wrong!
2)  Be darn sure that the reference points are adhered to throughout the build.   A couple of points on this one.   Hahn's drawings use a 1/4 inch build board, I used 3/16 inch thick board.   My confusion came on as I thought his measurements went from the bottom of the build board up.. they didn't.  Only the frame drawings had the full build board thickness and I made a faulty assumption but apparently not consistently as I'm off as much as 1/16th of inch in places.
3)  Add reference lines in the cutting process of frames.  I took measurements after the frames were cut and was led astray by 2).
4)  What I found acceptable even two months ago in my build, I find unacceptable now.
5)  I've discovered better ways of using my power tools with time and usage.
6)  Use only quality wood and reject out of hand anything less than quality.  There's places where I "made do" and I'm less than happy about it.
7)  Keep the fingers away from spinning tools -- like milling bits and saw blades.
8)  Even the master messes up.  I noticed in photos that there's errors where things just didn't go together right on Hahn's model and he tweaked it.
9)  It's a hobby dammit!!!!!!!!   Slow down and enjoy the trip not the destination.
Anyway, thanks for following along on this journey of discovery and I hope the next will be better.  It has to be since I learned from this one.
Lastly, expect more idiotic questions as I go... It's still a learning process.
See you on Licorne... Version II.
Hi Mark. Sorry to hear about the need to restart the Licorne. Reading your points of learning I see
that I've suffered each and everyone of them but unlike you l haven't learned from them.
Good luck with Licorne 2.0.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Mark,
Sorry to hear that you've thought it necessary to suspend your build,  It's really good to hear that you're treating it as a learning exercise.
Onward and upward to version 2.0 (or is that 1.2?)
John
Mark:
It is too bad that it came to this, but I get where you are coming from. We have all been there at some point. I look forward to the next build.
Russ
Mark, Your work has to continue to satisfy your desire to continue, when this changes for whatever reason, one sits back and reevaluates the whole process and why we engage in it in the first place. The bottom line is that sometimes there are too many issues to continue, and so a restart or entirely new build usually results.
Your reasons regarding the differences in information would most likely become more and more frustrating, so I can see and understand your decision.
I have always felt that the journey is far more important than the destination, and you have obviously used this journey well.
I look forward to seeing your next log.
Michael
Very sorry to hear this.
Your log was a great inspiration and helpd me a lot in the last year to find my way. To much perfectionism is also bad, You will never be satisfied with the result of your build. This was/is my biggest problem. Your log helped me to come out of this spiral and I found the fun on building a ship model. Thanks for this.
Regards Christian
Sorry to hear it got to this point Mark, but think of it as just another "do-over" (only on a larger scale)! :D
Mark,
I'm sorry that the issues you found were troubling enough to start over. It's really a hard and personal call.
Thank you for sharing some of your lessons learned in your build. I'm sure version 2.0 will be much more satisfying.
Harvey
man....what a shock to the system!   having to get up from a sound sleep,  to go to work is bad enough.........but to get all those notifications in my E-mail,  and come in here to see this.....why....it's beyond words,  my friend!  I am deeply saddened to read that you've scuttled your build........I can understand :(    I've had doubts in a few builds myself.......but I am but a crude method-ist.......I'm used to my little quirks ;)   I'll look forward to your restart.
is there no way to rename her and perhaps launch her under another flag?   you could simply turn her into a pirate ship........pirates love scuttled ships  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Mark
Sad news indeed.
However as you mentioned it is still a hobby.
Perhaps  -only for a while-  take some distance from it and  depending from your persoonal taste enjoy a few good beers or a glass of wine,  make a stroll,....
and very soon we'll be following the Licorne version 2.0 buildlog.
Take care !
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Mark, I don't think that I could do what you're doing -- in fact, I know that I couldn't. I'm sure that I would try to tweak it to be "good enough". I have nothing but respect and admiration for your decision not to do that. Like everyone else, I look forward to version 2.
Bob
Hello Mark,
I guess that post 466 must have been one of the hardest posts you have ever written. Thanks for the Lessons.
I am kind of speech less… But I wish you the best with the Licorne V.2.0. I think all that mental effort you have done once will make easier the path ahead…
Best wishes again.
Daniel.
Hi Mark,
If I would have to face this situation,  I would also think that it is a difficult way to learn. But the desire to build and create is much more stronger.
I tried ounce the the Hahn way with the frigate of 44 guns, I would not try it twice, the main reason being I do not like to work upside down.
Did you know that some 20 or 25 years after  Hahn, a little  genius by the name of David created a method:
- much more enjoyable to build
- much more similar to the real method to build and
- much more easy to build
Mark, you will probably want to go  in the Licorne V2.0. I am not trying to tell you not to go. I just wants to make sure that you are aware that there are easier ways to build  and mainly that you will get plans in a much higher degre of accuracy and details with peoples like David and Ed, and that the better the plans are the better the results are going to be... it is simply mathematic.
Mark: after your investment of time and money, that is a brave decision you'll not regret.
My first serious scratch build, many years ago, ran into many of exactly the same problems as you describe. I, too, decided to junk her. On my next model I was able to avoid all the pitfalls I'd fallen into the first time around. I ended up - some years later - with an award-winning model. May this be your experience also!
This is truly devastating news.  I can imagine how you feel terminating the build but applaud your attitude to take it as a learning experience and soldier on with another project.  This experience will certainly guide your modeling career as you move ahead.
Your many dedicated followers here will patiently await you selecting a direction for your next venture.  Though Licorne may have brought you valuable experience, she also brought many friends and acquaintances eager to see your ultimate triumph.  I am but one among them.
GOOD LUCK, my friend.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Sorry to hear this Mark.......I look forward to version II.
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
man....what a shock to the system!   ...   I am deeply saddened to read that you've scuttled your build ...
A PIRATE Ship !!!!!
Ye gunna turn her into a PIRATE ship ?!?!?
She'll be the grandest pirate ship I (err, that is, WE) e'er sailed the Seven Seas in !!!!
Oh !!! What a joy this shall be !!!
I'll (sorry, WE'LL) plunder the Spanish Main like it's ne'er been plundered before !!!
Just think of the damsels-in-distress to be rescued !!!
Oh please say ye will, Mark !!!!!!!!
:cheers:
DRAKE !!! Ye murderin' sea-dog !!! I (my mistake, WE) be comin' after ye NOW !!!
Edited by CaptainSteve
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Mark,
Just like Popeye I found this out when I was at work because of all the notifications !
A brave decision !
This build was make with sweat, blood and now tears........ :(
The Licorne 2 will even be better !
I will keep my seat and watch you again !
And then as a last thing, a famous Dutch expression........pfffffffffff
Good luck my friend !!!!!
in my case, when I mounted the frames, also had serious problems.
I made the wrong decision to continue.
I regret it every day. I think starting over is better than continuing something that was manufactured wrong at first.
greeting one cabrapente
Hey Mark,
Sorry to hear but totally get it.  Like Gaetan mentioned - maybe consider an Ancre Monograph or a Swan ?  I just think the plans are so much better as they are newer.  Whatever you decide to build - look forward to following your log.
Chris
Sad day!! :( I guess it's ultimately a good decision.  I know you wouldn't have been able to live with this one had you continued.  The second one will be all the better for it.  We're routing for you Mark.
Like Druxey, my first plank on frame model was scrapped after a year because it was not up to spec. Your second version will no doubt be built on a better foundation and I guarantee you won't regret starting over.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
