Superb workmanship danny,   so much detail  - amazing.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
really super looking structure Danny........so much detail.   gonna look awesome when you start populating the deck  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you all :).
The Control Top is now fitted to the rest of the Bridge. I'll leave the whole assembly off the deck for now in case there are other things to fit to the deck first :
Now I've moved on to the next assembly - the forward funnel. I've made the base for it, but before I continue there are 5 Rubber Boats to make. These mount on the base.
Here are a sequence of pics showing them being assembled in a jig. I made this to hold the boats while gluing up the sides, as they are very "slippery customers" to hang onto. First pic is of the parts for 4 boats in various stages of preparation :
The Holding Jig, made from card :
The jig in use :
The boats fitted to the base :
Danny
Cheers, Danny
Danny,
love those stairways and rails, next to other accurate details, outstanding modeling in card !!
Nils
Current builds
-Lightship Elbe 1
Completed
Once again I'd like to thank my followers for their kind comments :).
There is a fair bit of work to do inside the Funnels - Walkways and Railings from PE. In the pic below I've painted half of them matt black, as they are a bit more visible in primer :
All painted :
The funnel guard(?) is a bit flimsy before it's fixed in place. I used the back of a foam sanding pad to shape it with a toothpick :
The guard (still in primer) CA glued in place :
An angled rim covers the ends of the guard :
The Forward Funnel is nearing completion. I've been simplifying the way I use the laser-cut framing - with experience I've nearly stopped adding extra card to them. Here the funnel is being skinned :
And attached to the base I made earlier :
Danny
Cheers, Danny
nicely done Danny......never knew there would be railings and walkways in there.  chalk that up to a dirty job  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks lads :).
The forward funnel finished with all the pipework :
The Aft Funnel has turned out a bit better than the forward one - nothing like a bit of practise to make improvements :). I made a few small mistakes with the other one, which I've avoided with this one. Most noteworthy was the fit of the top flange - with this one I notched out for the PE guard :
The internal railings also came out a bit better on this one :
I also had the main seam on the wrong end with the first one. Luckily I did a reasonably good job of fitting it, so it won't be a major concern. Here's the completed aft funnel :
Danny
Cheers, Danny
2 hours ago, reklein said:
Nice work, I'm really jealous. Makes me wanna break your fingers
You are lenient Bill ...
Marvelous work Dan. You are certain there are no plastic parts :huh:  ........ ;)
Carl
My thoughts exactly. I had no idea there were walkways inside the ship funnels like that. First time I have ever seen that detail modeled.
As Carl said, the details captured in card here are astonishing.
Thanks for the comments guys :).
There are two platforms which fit either end of the aft funnel. These have a number of small fittings. Here's a couple of pics of how I roll the gearbox of a winch using the cutoff eye of a needle :
The two winches sit atop the forward platform, here are the parts for them and a pic of the finished articles :
On either end of the aft platform are two Searchlights, consisting of about 16 parts each :
The aft platform ready for fitting to the funnel :
The forward platform also finished :
Danny
Cheers, Danny
Thanks Greg.
There are three pipes between the funnel and the forward platform :
I've fitted the two platforms to the funnel base :
Danny
Cheers, Danny
Hi Danny, my first post in your build log but I do check in regularly.  What you are achieving here in card is extraordinary - very nice work indeed.
cheers
Pat
Edited by BANYAN
Its going to be a true museum piece of art,  I so hope you construct a fitting show case for it,  your amazing work so deserves to be shown to its full potential.
OC.
Current builds
Completed works.
Looking really great. I love all the details! Just curious- what’s the tall cylinder at the forward end of the forward platform?
~ Ben
___________________________________________________________________________________________________
Current Builds:
'Doll-Boat' - 1:12 scale 40' Cruising Sailboat
S.S. Edmund Fitzgerald - 1:350 plastic kit w/ Photo Etch Parts (On Hold)
stunning work in card Dan....
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you all once again :).
The Aft Superstructure is fairly simple, consisting of only 3 levels. Here is the lowest one :
The 2nd level, complete with two searchlights :
Danny
Cheers, Danny
Funnel walkways?! Ugh, I don’t want whatever job those walkways entail. I have to imagine it was solidly coated in inches of black soot. The interiors or upper surfaces of the funnels of large ships are not well documented and I would like to know more about them. I know that with steam powered ships their height is a factor of the physics of the rising column of hot air and steam and that forced draft funnels add complexity and machinery to the interior of the funnel. I would love to hear a lecture on the inner life of big ship funnels. Anyone know of any source material on the subject?
Quote
 Niagara USS Constitution
