Thanks for the comments and the likes.
I'm plugging away at the stern still.  I took a look at what needs to be done to the bow and that's simple.  This back end is bit of a problem as instead of looking ahead maybe 10 steps, I need to think backwards from the final look to "how do I get there".   I hope to have it resolved in a week and then start making sawdust and hull planks.
After pounding my head against the wall with the stern, I'm ready to start cutting planks and getting the hull planked.  I've decided to just build the "guts" to take the planking and window and line the inside with blackened wood.  Following the plans at this scale meant all the supports and ribbing were so flimsy, they'd break just looking at them.
Now get the saw adjusted and start cutting swiss pear.
Looks  good Mark, be nice to see you get some planking  on her, but don't they make you tear your hair out!!, I'll admit I'm still trying to get the Triton stern sorted.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
In this case, it probably was my doing.  The other monographs I have are for full framing but this one is bulkheads and the stern is show framed.  Confused the h*** out of me.
Looks like you have achieved a good form for your planking to go onto Mark; happy sawdust making.
cheers
Pat
Thanks for the likes and comments.
I've started sorting out the planking requirements and tomorrow is wood ripping day.
4 hours ago, KentM said:
So, why didn't you do a plank on frame?  Just wondering.
Kent
The plans are for this one are plank on bulkhead and I think they're the only ANCRE plans that are.  I don't have the skill set to loft frames and I'm just trying to use my time as best I can.
I feel reassured by all the posts indicating people having trouble with their models' transoms/sterns...
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
she looks great, i am starting to understand a lot more how these vessels were put together and as a result  im so happy i have taken the chicken route, and got a kit,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Very nice building. Place the strut in the stern, remove it after gluing the boards. Good luck!!:) Ondras.
Ondras.
Done : President - https://www.modelforum.cz/viewtopic.php?f=177&t=90230
Under construction : Roter Lowe - https://www.modelforum.cz/viewtopic.php?f=177&t=114576
Member of the organizing clubhttps://wchs-c-2023.klom-admiral.cz/en
Finally, an update.   After several tries, I finally got the garboard strakes like I want them.  Here's photos of side fore and aft.  On to the wales area.  I'll touch of the sanding and possibly need to add a bit filler up there.  Things got bunged about while doing the garboards.
2-1a.JPG.9104ef820ee0ac4cfa4f4efd5e4afbfa.JPG2-1b.JPG.2492b1fb9c56c7eaa5300faead6f018c.JPG
Thanks for the comments.  I appreciate it.
I have cut some planks and still sorting out the top of the main wale.   Unlike other ships, the French practice (on frigates at least) from the upper "wale" the planks taper down in thickness.  I'm figuring out things including wood cutting at the current time.
perfect sanding on gunwales shapes Mark. like . that must have been tough. Vlad
Thanks.  Not to bad actually.  I have couple of cut off pieces of plastic pipe in various dimensions. Wrap the paper around it and it does curves nicely.
Vladamir, I think we all have those moments when our brains go mushy.  I"m lucky I haven't forgotten my name yet.
Gary, thank you.  I"m not sure about the 'real shipbuilder' part though.  :)
Ah, the joys of getting older.   I heard the cell phone about week and ago and couldn't find it.   It was in my pocket.  I'm just about ready for the home.
These thing happen so our children can laugh at us😁, like when I'm looking for my glasses only to realise I'm wearing them🙄🙄
Current builds;
Completed:
What a joy it is to watch people work their magic. So entertaining and educational too.  Can't wait to see the planking 🙂
Tom.
Tom (MadDog) McQuiggan.
Member of Nautical Research Guild
Current Build : VAPORETTO MOTOBATTELLO VENEZIANO           Finished Build : AIRFIX 1930 BENTLEY
And Later On : PANART VICTORY BOW SECTION                           Finished Build : BILLING BOATS, ST ROCH
And Later On : EBBRO CITROEN DS21
HOBBIES : Amateur Radio : Motorcycling : Model Making : Painting/Sketching : FlightSims : Photography : Slave to none!
This ship isn't dead, I've just been busy.  Seems real life is in the way and also some reworks of things I've found I'm not happy with.  But, I think the ship problems resolved and once I've laid down some hull planks, I'll update things.
