HMS Kingfisher 1770 by Remco - 1/48 - English 14 Gun Sloop - POF
Hey Remco, om van te watertanden!  Translation: "to drool over."  Your hypodemic nurdles sure got a workout.
I need to make 4 of them suckers, triple sheaf fiddle blocks, more like base fiddle though ;-)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Share on other sites
Thanks guys. Progress is a little slow, making the blocks hasn't got me over the block yet.. I'm not mass producing the blocks other than the method described in TFFM vol 4. I've seen how Chuck does it, clever but whenever possible I like to avoid powered tools. Cutting by hand is more satisfying and I'm not on any deadline to get things finished. And doing a repetitive task helps to clear my mind, that's what the hobby is for.
That said I had to turn the shaves on my lathe  :o
I found making bigger blocks harder than the small ones, getting them the same shape and size was necessary as it really shows.
Remco
ps Pat, you can always come over and scavenge my scrapbox ;)
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
 Remco,
Wonderful as always.  And as always.. a fine tutorial. :)
Link to comment
Remco,
really wonderful. You show that it's possinle to make workable blocks in 1:48. Thanks for sharing
Regards Christian
Link to comment
Link to comment
Another great job as always. Thanks Remco!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks all.
So the metal work is blackened and installed and it's time to do some rope work. Believe it or not it took me one whole evening to understand the text in TFFM how the block should be stropped and how the rope needed to be spliced. But I got it and spliced the rope properly tying the individual ropes with small fly tying rope to prevent them to unravel. This worked better than a spot of glue as the glue wears of pretty quickly once you start splicing the rope. The blocks are BIG compared to the mast. Nothing refined about it just hardware made to do a job.
Remco
Link to comment
Remco,
If that's the size the drawings call for then that's what they are supposed to be.  You'll be surprised that once the masts are mounted to the ship and the rigging and spars are on they'll look quite right.  It's the function that counts.
Looking very nice indeed.  I hope mine will look as nice as yours.
Cheers,
                       VOC Ship Surabaya
Link to comment
Remco,
Nice work on the stropping.  I have question.  Obviously this is block and stropping for a heavy load.  Is it actually supported/secured to the mast by that one light line? Or this just for position only?
Link to comment
Thank you Karl.
Thanks Mark, it's just a line for positioning. I have to make a special cleat and rope to attach the blocks to the tops. You'll see.
Mark II, here's the how to. I used this link to understand how it works: http://www.animatedknots.com/spliceshort/index.php?Categ=splicing&LogoImage=LogoGrog.jpg&Website=www.animatedknots.com
First the length I need is laid out and tied off at both ends. The tips of the ropes are dipped in CA to prevent from unraveling
The ends are brought together and tied again
Then the lines are spliced using a needle, it took some time to understand how this works as its quite confusing
I opened the eye of the needle so I can insert the rope easily
The finished splice
The loop is glued to the block
And then seized at both ends
The result
Remco
Link to comment
Link to comment
Wow, I did not thought, that this is possible in 1/48. Absolut incredible.
Regards Christian
Link to comment
Your pictures of splicing are fantastic.  I have never seen a better explanation of the process.
Toni
Chairman Nautical Research Guild
Current Builds:     NRG Rigging Project
Completed Builds: Longboat - 1:48 scale       HMS Atalanta-1775 - 1:48 scale       Half Hull Planking Project      Capstan Project     Swallow 1779 - 1:48 scale               Echo Cross Section
Link to comment
Very nicely done Remco.... now you know how to do it......
Michael
Link to comment
Nice Splice!
Maury
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
