Hello Greg,
the belaying pins look very realistic. A very fine shape.
In addition, the Speedwell will be a fantastically beautiful model. The beautiful woodwork is admirable.
The standing rigging of the lower masts also looks really great. I look forward to the progress of the work.
The belaying pins are now installed in their shroud deflectors. That's a term I had never read before but that's what they're called according to Markquardt. Perhaps they're called pin rails only when affixed to the inner bulwarks. The deflectors have grooves filed on the outboard edge for the shrouds and lashings inboard and are surprisingly strong once attached.  At any rate, I was able to hone my lathe technique to turn out consistent pins. Next it's on to ratlines. Perhaps Archjofo would fly in from Germany to show me how he successfully duplicated actual practice when securing them to the outer shrouds. Personally. I believe he used Photoshop as this is not humanly possible to do.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
so very very nice
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Greg,
Couple weeks late but better late than never in reading up on the belaying pins.   You made my day!   I do wonder how small one can go (1:64??) before considering going to brass.   Even then, starting with the thicker rod makes a ton of sense, thank you very much for that tip.
Allan
10 hours ago, allanyed said:
Greg,
Allan
Just for fun I tried to turn a smaller belaying pin from the box wood and was able to turn the pin portion down to 0.010" but when I  turned the handle portion at 0.015" the pin portion whipped and separated off. perhaps you could make them in two sections as Druxey does.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Hallo Greg wirklich tolle Arbeit und ich war so beeindruckt von deinem Bautagebuch, dass ich mir die Bücher gekauft habe, aber es wird wohl noch etwas dauern, da ich gerade erst mit La Palme angefangen habe.
Gruß Tobias
Edited by Tobias
Greetings Tobias
Member of the:  http://www.arbeitskreis-historischer-schiffbau.de/
On the workbench:
Corvette La Palme (L'Amarante) from 1744 POF based on plans by G.Delacroix
https://modelshipworld.com/topic/32046-la-palme-by-tobias-136-pof/
LE ROCHEFORT - Harbor yacht from 1787 1:36 by Tobias (monograph by G.Delacroix)
https://modelshipworld.com/topic/34810-le-rochefort-1787-by-tobias-136-harbor-yacht-from-ancre-monograph/
Le Coureur - Kit from CAF with the plans from Ancre
https://modelshipworld.com/topic/29843-le-coureur-1776-by-tobias-caf-148/
A small Speedwell update. The lower ratlines have been installed as well as the euphroe tackle and crowsfeet. On many models I see they appear oversize. At 1/4" scale though we should be able to approximate the 1" ratline and 3/4" crowsfeet diameters. For the ratlines I use Guterman polyester Mara 120 thread (dark brown). For the crowsfeet I used 6/0 Uni-Thread, dark brown. I tried 6-0 silk for this but it just kept fraying (such is the nature of silk). I must admit that making the euphroes with their numerous no. 78 drilled holes (there are nine in the main euphroe), setting up the euphroe tackle and rigging the crowsfeet was an exercise in patience (and frustration). I was so pleased with my first attempt until I realized that I had reverse rigged one hole and had to redo the whole thing.  Onward and upward (literally)!
1.thumb.jpg.4e69f2e6edfe7484b96dfc0d9508f502.jpg2_edited-1.thumb.jpg.666b64b5d1fe732ff9203f51ffd1776b.jpg
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Finally some free time to look around.... It's just not right that such works of art are created only for the ships of a few major sea nations 🙂. And out of sheer jealousy, I decided to create plans to enable the construction of a similar jewel 🙂. I love structural models.
That looks sweet, Greg.
Toni
Member IPMS
                           Utrecht-1742
Greg:  What thread to you use to make your rope?
Your crows feet look fantastic.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
All rope is from Syren Ship Model Company. I have made rope but theirs is the best around in my opinion.
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Ditto congrats and 'well done' with those crows feet and the euphroe blocks - very nicely balance with fine detail.
cheers
Pat
Sweet progress, Greg!  I can't argue with you about Syren's rope.  I had considered making rope, and I will do so on a future project, but I think I will buy Chuck's rope on this go-around.  Anyway, fine line is nothing without tremendous skill, and you are doing a fabulous job.
Hi Greg
Its so nice to see you get it wrong sometimes. Makes me feel that i am part of the club. i have a  rope maker from Vanda lay that i have never used. If i do decide to install the gigging on the Thorn i will attempt to make some sized rope rather than just buying already size rope. As always your model is a work of art.
  • 3 months later...
Well gang, Speedwell is finished except for installing the anchors and adding coils over all the belayed ropes. It has been a seven-year collaboration with David Antscherl and I think the finished model has beautiful lines. She has just enough rigging to make it interesting without the repetition of a full ship rigged setup. Thanks to Chuck for his excellent blocks and rope which really dress up the model. All blocks for sails are included even though they are not present.
Thanks to all who have commented on her build over the years and I'll be back in the fall with, hopefully, a new project.
fin1_edited-1.thumb.jpg.112ff38d7a3a7ef14234b4b49274e5a3.jpgfin8.thumb.jpg.be92e4621f3457b302a0054dbe4bd2d4.jpgfin9.thumb.jpg.ac2fac7f53266d26bc56b65e151109dc.jpgfin10.thumb.jpg.6331a915b65c4095e4375e9ccb36d705.jpgfin12.thumb.jpg.526b7752a632bbb6fa1769b56880f0ec.jpgfin13.thumb.jpg.95ec0832d3aa3fa962d08248b210a37f.jpgfin14.thumb.jpg.78bad64e3f8e5a590a3053d73668dd5d.jpg
Greg
website
Admiralty Models
Finished build
Current build
Speedwell, 1752
Greg that is simply one of the most stunningly elegant models ever! Her lines are so nice, and your workmanship is exceptional.
It has been a pleasure following along and learning so much. Thank you!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Absolutely masterful job, Greg and beautiful carvings David! I look forward to building this and hope I can come anywhere close to this. This build log and your books will certainly be a massive help.
Ian
